20 Most Recent Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Questions & Answers
3answers
Black screen
You have probably formatted the hard drive when trying to install XP, XP is not compatible with Mac hardware. You will need to purchase a copy of the Mac OS or try and locate the restore disks that should have come with your computer.
4/6/2018 6:32:38 AM • Apple 13-inch... • Answered on Apr 06, 2018
I just updated to Sierra on my Mac. Now Farm Town won't load, and my flash is up to date.
My guess is maybe during the "upgrade" to Sierra the game may not have properly transitioned over. I would simply uninstall the game, restart the mac, re-download the game and reinstall it. If you need further help, I’m available over the phone at https://www.6ya.com/expert/brad_a1804065c704c462
10/18/2016 1:30:23 PM • Apple 13-inch... • Answered on Oct 18, 2016
I forgot password. how can I break it?
There is a beautiful video: watch it https://www.youtube.com/watch?v=ijc1eJVR9Qw
4/8/2016 6:30:20 AM • Apple 13-inch... • Answered on Apr 08, 2016
Want to signin and send info
Sounds like you need to reset password? If you have original disks. Put in disk and hold down C. It will then tell you it is installing. Once top bar appears after you have click continue on languages. Top bar has Reset password in about 2nd or 3rd unit on top bar. Once you have done this you can restart with new password. Hope this helps.
11/10/2015 4:18:30 PM • Apple 13-inch... • Answered on Nov 10, 2015
How do I connect a MacBook 5 and a bluetooth speaker?
Not only do you need a bluetooth connection, you also need an audio program that can access the bluetooth connection. Like not everything (almost nothing) will work on every USB connection on a PC without the correct driver and program, anything you try to connect with bluetooth, needs the driver and program.
3/9/2015 8:55:52 PM • Apple 13-inch... • Answered on Mar 09, 2015
Reset button
Hi Terry, Are you wanting to set your computer back? If so. You need to boot the system to the Recovery HD. Hold down Command+r key at startup. Open Disk Utility and erase the Macintosh HD. Exit out of DU and select Reinstall Mac OS X. Select Macintosh HD as the place to install to and wait for OS to be downloaded from the net. The computer will restart when the download is finshed and the install will start.
3/6/2015 11:15:27 PM • Apple 13-inch... • Answered on Mar 06, 2015
How to fix or repair apple macbook power plods and chargers
Hi Unless you are a skilled electrician with specialities in the field I would not recommend this action. Just in case - have you checked the contact point? Because it is magnetic it has happened that small metal objects have attached to the magnet and caused problems. Sorry I cannot help you more and hope you solve your problem
2/16/2015 2:18:16 PM • Apple 13-inch... • Answered on Feb 16, 2015
Get a stuck cd out of a macbook
Try rebooting with mouse down. Should eject all ejectable media. If that doesn't work, take it to service (Apple or other) - they have tools to do the job. Don't force it.
2/14/2015 3:41:48 PM • Apple 13-inch... • Answered on Feb 14, 2015
2answers
My iphoto won't update
8/8/2014 4:29:51 PM • Apple 13-inch... • Answered on Aug 08, 2014
2answers
CD/DVD optical drive malfunctioning. Invariable performance with reading and ripping CDs. Cannot read DVDs.
upgrade your CD/DVD firmware from MAC website and install it.
if it does same even upgrading driver then most could be problem in optical lens so better taking back in the same place where you bought it from if its still under warranty.
or if its out of warranty then you need to take to Tech so they can fix it for you.
please post back if anything changes and rate all answers.
7/20/2014 8:08:23 AM • Apple 13-inch... • Answered on Jul 20, 2014
Macbook a1181 works for a couple days and then
Your best bet is to reset the System Management Controller;
(I'm not sure if your model has a removable battery or not, so I'm providing both methods)
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
...and then reset the Parameter RAM:
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
1/24/2014 7:29:11 PM • Apple 13-inch... • Answered on Jan 24, 2014
4answers
Recently my Mac has become slow to load new pages
Generally there are a variety of reasons that can consequently the issues on your Mac. Meanwhile, there are certain ways through which you can do to fix one by one. However, if you prefer a more efficient way to resolve, try an all-in-one Mac speed up software as it can help resolve all issues in just a few clicks. Learn more: http://www.howtospeedupmac.com/
1/3/2013 10:11:24 AM • Apple 13-inch... • Answered on Jan 03, 2013
What to insert for PPPoE Service name to connect to internet
PPPoE stands for Point-to-Point Protocol over Ethernet, it's basically authentication for ISPs that use Usernames and Passwords to get you connected to the internet. If your ISP uses PPPoE you'll have to change the 360's settings to connect to the Xbox Live service. Your PPPoE info should have been given to you when you signed up for your internet service(some ISPs even print the info somewhere on your hub/modem), otherwise you'll have to call them up and get the info from them. It's also important to know that if you're ISP doesn't use PPPoE you should leave these settings blank on your 360 or it won't connect. Since you haven't connected to the live yet I'll assume you're still on the older dashboard so it should go like this: 1. Move to the System area of the Xbox dashboard. 2. Select Network Settings. 3. Select Edit Settings. 4. On the Additional Settings tab, select PPPoE Settings. 5. Use the on-screen keyboard to enter the PPPoE information that was provided to you by your ISP. 6. Select Done. 7. Select Apply and Test when you are prompted to do this.
9/7/2012 6:42:47 AM • Apple 13-inch... • Answered on Sep 07, 2012
Fixing error code 8003 on macbook
Did you modify your Time Machine files in any way using Finder or the command line? This can cause this error. There's a program called Trash It that might be helpful if all you want is to get rid of those files.
7/2/2012 5:59:55 PM • Apple 13-inch... • Answered on Jul 02, 2012
Water spilled on the table under the macbook. now it doesn't work. I see people wating a few days and it restarted. how nmany days should i wait? help!!!
Jay, Try placing your MacBook on a bed of un-cooked rice for several days that should pull any moisture out of your lap-top. DO NOT ATTEMPT TO TURN IT ON. If you already have it may too late.
5/6/2012 12:15:03 PM • Apple 13-inch... • Answered on May 06, 2012
3answers
My apple 13-inch MACBOOK got water damage, after
Your issue seem to indicate there was damage to the keyboard when it got wet. Drying out the laptop may have gotten it to function for now but it isn't really a substitute for a thorough cleaning by a professional (which might also solve your keyboard issue).
2/26/2012 3:35:44 PM • Apple 13-inch... • Answered on Feb 26, 2012
Display is too Dark to work with but brightness lever up to max.
Apparently the backlight for your display is failing. You'll most likely have to have the top half of the macbook replaced per Apple usual service standards.
2/26/2012 2:36:48 AM • Apple 13-inch... • Answered on Feb 26, 2012
2answers
I have a new Macbook, but it doesn't have a
Buy a USB card reader, this will show your card (which you used in the camera) as a normal disk in finder
12/21/2011 11:53:32 AM • Apple 13-inch... • Answered on Dec 21, 2011
2answers
How do you resest pram
I would try starting the machine up in single user mode you do this by booting your machine up and then immediately press and hold the command (Apple) key and the s key. If you do not know how to reboot press down the command-control-power key at the same time.Once you get white text appearing on a black background at the command line prompt type /sbin/fsck -fy then press return. The machine will then go through some testing and then hopefully it will tell you that your hard drive is okay. If it says that the file system has been modified run the comand again i.e. /sbin/fsck -fy When the fsck command reports that your hard drive is okay type reboot at the prompt and then press return. Hopefully your computer will boot up okay after this.
11/29/2011 6:11:52 PM • Apple 13-inch... • Answered on Nov 29, 2011
Hanging blue screen on 13-inch MacBook
The issue is with the software.Boot the system with installation media and go to disk utility and repair the file permission.This can solv the issue.If still the issue persist.Then go ahed and format the drive and re install the software
11/12/2011 11:01:20 PM • Apple 13-inch... • Answered on Nov 12, 2011
Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Logo
88 questions posted
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Computers & Internet
Most Popular Question
recently mac become slow load new pages
  • Computers & Internet
