Please help - I am having the same problem with my Brother PE-150. Any help would be greatly appreciated! Please help - I am having the same problem with my Brother PE-150. Any help would be greatly appreciated!
You can't post conmments that contain an email address.
try changing the needle try rethreading the machine top and bobbin make sure to use every thread guide-this is improtant for the thread tension make sure the bobbin is turned correctly in the bobbin case also could be a problem with the computer motherboard or there could be a problem with the timing
try changing the needle also rethread the machine clean under the needle plate & in the bobbin area for loose threads or lint if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
Check that the needle is in the right way, flat shank to the back. If it is around backwards, the shuttle hook won't be catching the thread at the back of the needle to form the stitch.
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
The "race" on your machine needs adjusting. Remove the bobbin cover, bobbin, & case. What you have left is the race, it moves when you turn the large wheel on the top right of machine. The needle also moves up and down. There is a hook on the race that catches the needle thread. Try moving the race to the line up with the needle. It may take a couple of trys but it should do the trick. Also clean any threads that may be caught on or arround the race. Hope this helps!
See if you may have thread wound up inside the bobbin hole. The hook needs to cross the needle hole when the needle bar starts up. Adjust needle bar to make up for it.
