Question about Hardware & Accessories
I have a noma 49550 and the timer let the turn on and the wheel spins as well but it doesnt shut off even with the pins and i dont know what the wheel at the top is for, is that the issue???? please help greatly appreciated
I don't have repair for defective timer.
The wheel at top is probably the issue. Move the wheel with your thumb and experiment with the timer.
As a general rule, the timer will not bite you.
Open following link for analog timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
My files show that 49550 is analog timer with trippers that install on timer dial.
http://waterheatertimer.org/Woods-timers-and-manuals.html#49528
Posted on Aug 19, 2011
SOURCE:
On the Noma timer Mod 49550/tm151p how can you tell when the switch is on
1) Noma is old Intermatic brand name used by companies today to brand their timer.
2) Noma is usually associated with Woods timers.
3) Woods numbers also frequently start with 495 and with TM.
For example Woods has 49588 49556 and 78 84 29 28 62 57 33 53 65 44 68 32 77, but 49550 does not show
4) It is likely that you have a Woods brand timer.
5) Add a comment with in-focus photograph of timer for possible identification
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
6) Open following link to possibly identify timer, and then add a comment saying which timer is same-similar to yours.
Read troubleshoot section to see if your answer is there:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Apr 22, 2011 | Hardware & Accessories
Our timer does not seem to be working right. I have lost the book. I want it to be on from 6-9 p.m. every night. Can you help?
Here are generic troubleshooting steps:
If plug-in timer doesn't work
a) Check receptacle for power
b) Check lamp is turned ON
c) Check bulb is good.
d) Mechanical timers: Check tabs or pins are set
e) Check override switch pushed fully in position
f) Try timer in different plug and with different lamp
g) Test circuit with inexpensive circuit analyzer from hardware
h) Don't exceed maximum wattage
i) Programmable: check for overlapping programs
j) Programmable: write out programming steps and double check. Reset timer.
k) Outdoor with photo cell > test with black tape over photo eye
l) Turn photo eye away from light source
Add a comment any time
Next step would be to identify exact timer, and check steps in manual.
You posted under Noma programmable 6 button timer:
Your timer may appear among timers on next page > each timer has link to manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
geno_3245_165.jpg 6 button 7-day
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
geno_3245_166.jpg Generic 6 button Week
Dec 10, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
LOST INSTRUCTIONS FO NOMA TIMER MODE ET420C
Page shows all ET series timer manuals.
Including ET420 and ET420C
ET420 appears to be a plug-in outdoor timer
http://waterheatertimer.org/UPM-timers-and-manuals.html
UPM website that posts these timers seems to be shut down.
Nov 23, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Noma Multipurpose Timer, I pressed the grey buttons down and set it to the time I want it to start but the lights still won't turn on!
I answer questions for free.
I specialize in timers.
Noma is a Woods timer.
But Woods makes lots of timers.
I probably have the manual and can look up the information.
But I don't know without the model number.
If you know the model number, add a comment, and I will answer for free.
If you want to post a photo of your timer, I can look at it that way.
The following link shows how to include a photo of your product when you add a comment:
Oct 31, 2010 | Hardware & Accessories
Would like the above question answered. it wasn't
I also forgot how to set the timer. Start with all pins pushed outward. Only push inward toward the center, the pins (time) you want the timer to turn on the item.
Dec 23, 2009 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Dec 01, 2008 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Machine wont aggitate,supplies water then sits,can sometimes
Dont know what type of unit you have, but that usually means that you have a timer that is going bad, or has already went bad. You can also have a bad water level pressure switch, which shuts the water off, but doesnt send a signal to the timer. Both are located under the console.
Nov 16, 2008 | Washing Machines
Need help asap, please!
Turn your timer to spin cycle ( doesnt need any water)and turn it on.Now if its starts spinning and than shuts off immediatley turn it back on, if there is nothing happening when you try this >>>Replace your motor.There is a 15% chance that your timer is broken and is sending improper current to the motor.First change motor.If you have been running this on a extension cord or when your community is using alot of electricity it would be the reason your at this problem.Dont run Appliances on super Hot Days ,use them in the evening and your motor will run at a low temperature. Please Rate This !!!
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Hardware & Accessories Logo
765 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
