20 Most Recent Woods 59200 Lamp and Appliance Timer with Easy OnOff Settings 2Prong plu Questions & Answers
with a timer like that , start here. Unplg it and have it in your hand. Pull up all the tabs. Push down the tabs from 7pm-6am. Now, find in the center ot the unit, the little arrow, turn till the correct time, the the right now is at the arrow. Plug in right away. As for the timer switch, timer on will work just as timer, push to outlet on will turn the lamp on manually. Also keep in mind that if the power goes you will have to realign the arrow with the actual time.
Woods 59200 Lamp... | Answered on Sep 08, 2018
See following link to identify your timer with instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59419
Rotate dial until current time lines up with arrowhead; when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
If this is not your timer, then add a comment
If you do not want additional free help, take advantage of fixya phone support.
For a price, fixya expert speaks to you via phone while you set timer.
Woods 59200 Lamp... | Answered on Jan 16, 2016
1. Begin with all timer segments on the dial 'pushed up'.
2. Push 'down' the segments required for the 'ON' time;
each segments represents 1/2 hour interval.
3. Rotate the dial clockwise until the 'TIME NOW' aligns with the pointer.
Woods 59200 Lamp... | Answered on Mar 02, 2015
Link above has most woods timer manuals
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Woods 59200 Lamp... | Answered on Dec 12, 2014
Question posted under analog lamp timer:
Open following link for written instructions for setting analog timers:
http://waterheatertimer.org/How-to-set-timers.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Woods 59200 Lamp... | Answered on Aug 27, 2011
59200 is analog timer with moving parts including motor, switch and contacts.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
I test timers. Some timers make noise, and some are quieter.
When a timer goes bad that I bought from local store, I buy another one and return defective one in new package.
Digital timers make no noise, except humming sound, and click when contacts are activated sometimes.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Woods 59200 Lamp... | Answered on Mar 30, 2011
It depends on wattage being controlled.
You posted under Woods 59200 timer which is a lightweight table lamp timer.
I suggest more robust 110V Intermatic HB113C appliance timer.
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
If you are not wanting a plug-in timer, add a comment with specific requirements.
Add a comment for more free help.
Woods 59200 Lamp... | Answered on Feb 27, 2011
The segments lift up as you discovered.
Lift up about 10 consecutive segments and then manually rotate timer dial and watch when lamp turns on-off.
I think the problem you describe results from lifting only one segment, instead of all segments between the on-off times.
The dial rotates as time passes, and pins-tabs push tiny switch one direction or other direction, and switch turns light on-off.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Woods 59200 Lamp... | Answered on Feb 21, 2011
They are located on outer edge of dial.
See samples of timer pins and segments:
Woods 59200 Lamp... | Answered on Feb 20, 2011
Open following link to identify timer and see manual plus written programming steps:
Lamp must be turned ON, and Bulb is good.
Raise and lower a few segments on the timer.
Plug timer into wall, and plug lamp into timer.
Manually rotate timer dial clockwise to watch lamp turn on-off.
Notice also that timer has switch located on top.
Move switch into one position and manually rotate dial again.
Move switch to other position and manually rotate dial again.
This will tell you how to set timer switch and segments.
To set current time, rotate dial until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and segments click a switch back and forth that turns circuit on-off.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Woods 59200 Lamp... | Answered on Feb 08, 2011
Open link below to identify timer, download manual and read step-by-step instructions
Woods 59200 Lamp... | Answered on Feb 05, 2011
Push in all pins for the duration that you want your lights to come on. For the timer to control, switch should be on "timer". For constant on, switch should be on "outlet".
Gary
Woods 59200 Lamp... | Answered on Jan 02, 2011
Ensure that the switch on top of the timer is in the "timer" position.
Rotate the timer dial to set the correct time of day.
Push down all pins for the time or times that you want the device to run.
Plug the timer in and plug your device in.
Gary
Woods 59200 Lamp... | Answered on Jan 01, 2011
Woods 59200 Lamp and Appliance Timer with Easy OnOff Settings 2Prong plu Logo
37 questions posted
Top Woods Hardware & Accessories Experts
Gene Haynes
Thomas F. Schneider
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Woods Hardware & Accessories
Most Popular Question
set
  • Hardware & Accessories
