i have the same problem. when i turn tv on green lines show. Then in seconds it turns green. Is this problem easy and cheap to fix ? Can i fix it myself?i have the same problem. when i turn tv on green lines show. Then in seconds it turns green. Is this problem easy and cheap to fix ? Can i fix it myself?
You can't post conmments that contain an email address.
Mar 7, 2009 - 30 posts - 25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl 40bx421
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced. If you need any information or other assistance let me know. Thanks, Lee
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
The light engine on your set is burned out.
This is a very complex replacement.
I hope your tv is under warranty repair cause it is expensive.
It happens because the heat from he lamp over time burns out the lcd's that create th ed and blue leaving the gren which is always furthest from the lightbulb (YOUR tv has four lcd's in a row..red, blue, gren and then black.
If you wish to try and replace it yourself there are places online where you can buy a replacement engine.
Sounds like the green tube shorting intermittantly. Have a qualified tech use a tube restorer to check for shorts, or the loss of the 300v line to the green tube.
screen goes green
