20 Most Recent HHP Alternator/Battery Tester - 125 Amp Load Hand Held Questions & Answers
HI:
When you press the load button it applies the load to the battery to wipe the surface charge (if any). What you are looking at is the recovery voltage should be just over or just under 12 volts if the battery is any good (look at the colored scale it will tell you if the battery is OK, and needs charging bottom end of green & start of yellow is OK, if its in red its dead, or close enough to be treated that way. DON'T hold load on for more than 10 seconds as this generates lots of heat that can warp plates & discharge gas that can explode
3/8/2019 6:25:39 AM • HHP... • Answered on Mar 08, 2019
How do i find the tension bar to loosen the v-belt
Tensioner pulley is located on passenger side head, just behind the fan shroud. There is a pivoting catch that will hold the tensioner in the "loose" position so the belt can be removed or installed. Stand on ladder or on the passenger side tire and pull up on the belt, Reach down and press the keeper in while holding tension on the belt. Release tension down on to the keeper. When belt is reinstalled, pull up on the belt to release tension from the keeper and release. The keeper will pop back into normal position and the tensioner will tighten against the belt.
12/26/2012 3:49:20 PM • HHP... • Answered on Dec 26, 2012
Can I use a standard hand held battery tester to
You can teat the battery with this, but you need a volt meter to test the charging system. Your battery should have about 13.5 volts when the ehicle is running. If you need further help, reach me via phone at https://www.6ya.com/expert/tom_1788908372a4836f
9/11/2012 12:41:17 PM • HHP... • Answered on Sep 11, 2012
I recently replaced my battery, alternator, as
You didn't provide the make and model, but it sounds like your voltage regulator has died.
4/21/2011 12:21:37 PM • HHP... • Answered on Apr 21, 2011
Part number for a 1600 lancia beta alternator
That would be a Magneti Marelli AA125E-14v-55A, Fiat part no. 66307400. But they're as rare as **** ****(although...) Some were fitted with a 65A version (only really needed on aircon models) and there's also a more widely available Bosch equivalent which you can get as a reconditioned item no. 13152 from here. I hope that I've been of some assistance and that you spare a moment to rate my answer.
3/1/2010 11:07:11 PM • HHP... • Answered on Mar 01, 2010
Driving along last night with radio on. all of a
new alternter required
1/18/2010 5:46:55 PM • HHP... • Answered on Jan 18, 2010
Small black broken wire on alternator where battery connects
if its a G.M. product and the small black wire comes out at the negative terminal cable it needs to be grounded to the steel shell alongside the battery or the vehicle frame
10/6/2009 8:24:39 PM • HHP... • Answered on Oct 06, 2009
Alternator on my vw is not charging above 12.5 and
Make sure your alternator warning light comes on when key is turned but engine is NOT started. The current through the lamp pre-charges the field of the alternator. Broken wiring or burned out lamp can cause your problem.
9/4/2009 5:40:06 AM • HHP... • Answered on Sep 04, 2009
Car hesitation while driving
Without knowing more about your problem it's hard to say what the problem is. However the fact that the radio went off and the battery light is coming on would indicate an electrical failure.
Have you checked the alternator? Also, your alternator may be fine, but the leads that connect it to the battery can become corroded and cause a poor connection. I experienced this exact issue on a 2002 Chevy Grand Vitara, the lead connections on the back of the alternator just had to be cleaned.
2/11/2009 6:07:19 PM • HHP... • Answered on Feb 11, 2009
0answers
Wiring to fuses
Be the first to answer 12/11/2008 6:24:42 PM • HHP... • Posted on Dec 11, 2008Be the first to answer
2answers
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
4/17/2024 8:59:53 PM • Measuring Tools... • Answered on Apr 17, 2024
Rf tech 433mhz manual model 217S31
I want to use an old sensor forgiven during 30 years. I have no more manual, off course. Thanks for your answer
3/26/2024 11:42:40 PM • Measuring Tools... • Answered on Mar 26, 2024
What are the readings on a meoisture meter measured in?
Most moisture meters measure the moisture content of wood or concrete is measured in percentages. So if the reading says 15 that means that there is a content of 15% moisture in the concrete.
3/16/2024 7:34:55 AM • Measuring Tools... • Answered on Mar 16, 2024
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
2/19/2024 4:57:31 AM • Measuring Tools... • Answered on Feb 19, 2024
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
1/21/2024 4:20:12 AM • Measuring Tools... • Answered on Jan 21, 2024
DSE Z111 Weather Station: Is the wireless sensor available for sale?
Unlikely unless you know the secret maker name and can find them in China. At the moment, no one has heard of it apart from here on Fixya. All questions need FULL 'make model (what it is)' please. https://www.google.com/search?q=dse+z111 ..
1/20/2024 1:59:56 AM • Measuring Tools... • Answered on Jan 20, 2024
How can I adjust the time on my weather station model #sgr72914?
  1. Access the Time Setting Mode:
    • Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
    • Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
  2. Adjust Hour and Minutes:
    • Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
    • After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
    • Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
  3. Confirm the Time:
    • Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
  4. Check the Time Display:
    • After setting the time, check the display to ensure that the time is displayed correctly.
1/7/2024 9:28:03 AM • Measuring Tools... • Answered on Jan 07, 2024
Starrett Tape Measure. Can I Replace a 1.5 volt Battery with a 3.0 volt Battery in it?
Question edited for clarity. Question moved from Motorcycles category. Of course not! You will burn out all the electronic components. You can't just double the voltage. Conversely you can't put a 1.5 volt battery in place of a 3 volt one. Get the proper battery. https://www.starrett.com/contact-us# ..
12/20/2023 4:55:24 AM • Measuring Tools... • Answered on Dec 20, 2023
Ascot Weather Station. Instruction for reset times please.
Ascot weather station manuals
Manua.ls https://www.manua.ls > Ascot > Weather station You are currently on the Ascot weather station manuals page. Choose one of the products to go directly to the manual for this product.
Ascot weather station user manual
Manuals.co.uk https://www.manuals.co.uk > Ascot > Weather station For those looking for a simple and straightforward setup, Ascot Weather Stations provides a quick start guide with step-by-step instructions to get you up and ...
User manual Ascot AUK-WS-32 (English - 6 pages)
Manua.ls https://www.manua.ls > weather stations > Ascot To install and set up the Ascot AUK-WS-32 weather station, you should begin by securely mounting the sensor unit in an elevated outdoor location, ensuring it is ...
Ascot GT-WS-06s user manual (English - 40 pages)
Manuals.ca https://www.manuals.ca > weather stations > Ascot User manual. View the manual for the Ascot GT-WS-06s here, for free. This manual comes under the category weather stations and has been rated by 2 people ...
Ascot Weather Station User Manuals Download
ManualsLib https://www.manualslib.com > Brands > Ascot Manuals Download 1 Ascot Weather Station PDF manuals. User manuals, Ascot Weather Station Operating guides and Service manuals ... Operating Instructions Manual.
12/10/2023 5:27:32 PM • Measuring Tools... • Answered on Dec 10, 2023
HHP Alternator/Battery Tester - 125 Amp Load Hand Held Logo
20 questions posted
Top HHP Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a HHP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • HHP Measuring Tools & Sensors
Most Popular Question
recently replaced battery alternator
  • Measuring Tools & Sensors
