20 Most Recent Leviton Decora Gray Rocker 4-Way AC Quiet Switch Questions & Answers
How do I wire a 4 way switch in my home
in order to wire a 4 way switch, there needs to be a total of 3 switches working to operate a device/light. you need a 2-wire coming from power source, 3-wire from first switch to 4-way switch then 3-wire to last switch. white wires (neutral) get connected together. Depending on the layout of the switches. i.e where the power comes from and where the switch leg goes to but a basic 4 -way switch is in between 2 other 3-way switches. 6928ae07-fbd3-4cea-b937-54088e9eede4.png c269cdb0-bf34-4ccd-bf2c-276a65791e3f.png
6/23/2014 8:36:20 PM • Leviton Decora... • Answered on Jun 23, 2014
I have a four way switch that is not working when
If you have a four way, it should mean you have two other three ways. lf so, wires are probably crossed. At each three way, you should have one wire on the dark screw. At one end, this wire will be the hot. At the other end, this wire goes to the light. At each three way, you still have two screws. these are the same color screw, and the wires on these are called travelers. They should only run switch to switch. When you have a four way, it is just in the middle of this run. so, two wires coming from one 3 way, and two wires coming from the other 3 way. Look on the box for the new four way, or see if it shows you which screws are in and out. Then hook up accordingly
3/3/2011 6:53:23 AM • Leviton Decora... • Answered on Mar 03, 2011
2answers
With the switch in the
I answer questions for free.
I understand electrical devices.
It is unclear how many screws are on the switch you are testing.
If your switch does not show ohms when the switch is in one position, then it sounds like the switch is bad. But you can read information below for more information about your testing.
You can also add a comment and continue the discussion.
Let me provide more information about switches because you seem interested in electricity and the information may help us understand where the other is coming from in case you add a comment needing more help:
2 screws on switch: (excluding ground screw)
An ordinary single-pole switch usually has 2 brass colored screws.
These screws only read ohms or continuity when switch is in one position.
When the switch is in the other position, there are no ohms that pass through the switch.
3 screws on switch: (excluding ground)
A 3-way switch has 3 screws. There are 2 brass-colored screws and one dark-colored screw.
Put ohm tester on dark screw and continuity will show between the dark screw and one of the brass screws.
Flip the switch and ohms will test between dark colored screw and the other brass screw.
4 screws on switch. (excluding ground)
There are 2 screws on each side of switch.
This type of switch might be a special purpose double-pole switch.
Or it might be the more common 4-way switch.
Add a comment if you have a switch with 4 screws.
Below is a typical 3-way switch application showing the dark-colored screws:
Here is a typical 4-way switch circuit:
Notice the switch in middle has 4 screws:
Link below goes to a special application double-pole-double-throw switch:
http://waterheatertimer.org/images/30-Amp-DPDT-switch-a-800.jpg
11/1/2010 10:02:36 PM • Leviton Decora... • Answered on Nov 01, 2010
4-Way Switch wiring
Here is a website that has great wiring diagrams for you and also a video about wiring these switches.
Your problem is that you have a "hot" going to a "common at one of the switches when you flip a swtich. This trips the breaker.
It can take alot of time and be very frustrating to find the culprit wire if you are inexperienced with three and four way circuits...it even takes a pro quite a while to figure these out someitmes. And Ohm meter is a must and you need to pull all the switches out with the power off and start tracing out each wire till you find the bad one.
You need to make sure that your switches are wired EXACTLY as the diagram shows.
http://www.askthebuilder.com/B141_3_Way_Switch_Wiring_Diagram_and_4_Way_Switch_Wiring_Diagram.shtml
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
12/28/2009 4:32:07 AM • Leviton Decora... • Answered on Dec 28, 2009
I have wired a 4-way switch in between two 3-way
Please review the instructions on the box for both the three and four way switches and review your work. You have a runner wire crossed somewhere.
12/28/2009 2:04:02 AM • Leviton Decora... • Answered on Dec 28, 2009
I am connecting three switchs to control one
The wiring method is power into the first 3-way switch, 3-wire to the 4-way switch, 3-wire to the second 3-way switch and 2-wire to the lamp. The way you terminate the wires on the switches is only important on the black terminals of the two 3-ways. Power and load go on these, the rest are just travelers.
11/20/2009 5:17:23 PM • Leviton Decora... • Answered on Nov 20, 2009
Can i test a four way switch with a meter?
Yes, you should have continuity between two screws, two times (total of four screws) If you have continuity between screw 1 and 2, then you should have continuity between screw 3 and 4. You should not (in this example) have continuity between 1 and 3 or 4. Hope this helps
10/2/2009 6:36:46 PM • Leviton Decora... • Answered on Oct 02, 2009
Where does the fourth (copper wire connect)
The 4-way terminals are labelled “In” and “Out” (two of each). The mechanics of this switch are simple, in that they either switch the travellers straight through, or criss-cross them.
(2) white wires - 1 on each silver terminal
(2) black wires - 1 on each brass terminal
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
5/26/2009 7:22:51 PM • Leviton Decora... • Answered on May 26, 2009
2 way light switches in the hall
there are too many ways to wire a 2 way switch circuit (3 way switch) to mess with, the two most common ways, will trip out the circuit if wired to each other, (one kind at each end, hope that makes sense), the most common mistake, will put 110v to the metal plate of the switch and switch box, not good
a sparky will take 5 minutes to determine which wiring pattern is used, and install the switch
9/26/2008 6:03:51 PM • Leviton Decora... • Answered on Sep 26, 2008
Installation Question
Make sure you are using three way switch's and not plain on/off switch's there is a difference. if you are using 2 plain on/off switch's the lights will only come on when they are both off. Find the power side with a meter. Put the meter on V A/C and hold the leads. One on the white wires that are connected together seperate from the switch. Id the hot wire. Now, go to the other side and id the hot wire on the other switch. Disconnect everthing on both switches. Find the hot wire again and on the side that the hot wire is on, put that hot wire on the bottom black looking phillips screw. Put the other two on the top of the switch. Go to the other switch and put the hot wire (black) on the top. Take the bulb out of the socket and put you meter on the beep continuity. Place one in the socket and find the other by oplacing the probe on the other two wires one at a time. The one that beeps goes on the black phillips screw and the one that doesnt goes on the other screw on the top.
8/27/2008 12:29:56 PM • Leviton Decora... • Answered on Aug 27, 2008
How do I connect a Leviton 6230M in line with a humidistat controller ... so any one of these sources will activate bathroom exhaust fan 120v ac
You parallel the contacts then either one or both will turn it on. Both have to be off for the fan to stop.
10/2/2021 3:00:18 AM • Leviton... • Answered on Oct 02, 2021
I cannot turn off light that uses a Leviton Cat /no 16400, DHC switch not can i find the receiver box that controls the lights
A Leviton DHC receiver device can look like any other switch or receptacle so if you didn't install it or not provided a map then you'll need to locate it.
Likely the wall switch that originally controlled the light was replaced with DHC device and paired with the 16400 at another location. If you can't identify it, then removing face plates and devices may be the only practical method to locate it.
If your not comfortable with removing devices safely, hire an electrician.
https://www.mc-mc.com/ASSETS/DOCUMENTS/ITEMS/EN/Decora_6375_Catalog.pdf
7/5/2021 2:59:40 PM • Leviton... • Answered on Jul 05, 2021
2answers
Thought I wired leviton 5224 correctly, but looks like switch for fan is ok, but the only time light switch works is when fan runs also, so must keep light always on. What can be wrong?
It's two single pole switches with a removable jumper on one side. With jumper intact, you connect the hot feed to a either screw of the jumper which I belive are brass colored screws.
Then the two induvidual switch poles are the silver screws. Connect fan motor to one and fan light to the other.
If that doesnt work for you, take a picture of the switch and connections and another of wires in fan box and post here.
4/9/2020 8:04:38 PM • Leviton... • Answered on Apr 09, 2020
My Leviton VPT24 Outside light switch went totally blank. The light do not turn on. Is there an internal battery?
https://www.leviton.com/sites/REST/controller/LCDownloadController/download/DI-000-VPT24-02F-W.pdf?docurl=/en/docs/DI-000-VPT24-02F-W.pdf Yes, but appears to be non-serviceable... and its probably just a 3.2vdc lithium coin battery inside the case yet they decided to make it so you have to buy a replacement every 10+yrs. Crack it open and see (dill off any rivet heads).
2/18/2019 11:23:31 PM • Leviton... • Answered on Feb 18, 2019
Does a leviton slide dimmer switch use regular bulb's
what do you know as "regular " bulbs are they low energy or incandescent
10/11/2018 5:50:39 AM • Leviton... • Answered on Oct 11, 2018
Dimmer slide does not dim
Replace it. They fail and and that is not uncommon. good luck
5/20/2018 4:04:38 PM • Leviton... • Answered on May 20, 2018
2answers
I have an old easyset E-600VA dimmer connected on single pole to a ceiling light. I want to replace that with a new Leviton toggle switch with dimming slide.
red never connects to black as that is power to neutral if wired correctly get in a qualified electrician to check the wiring and help you install the unit
5/1/2018 11:36:21 AM • Leviton... • Answered on May 01, 2018
How can I wire 3 Lutron Dimmer switches in a series? Each switch will control a different set of lights. I pig tailed the black power source to each of the dimmers. I ran the black wire from the l
yes, take the white wires off the switches and splice them all together with a wire nut. Run a hot wire to each of the switches and then run the switch leg (black) from each of the fixtures to be controlled to each of the dimmers.
12/18/2017 3:05:53 AM • Leviton... • Answered on Dec 18, 2017
I am trying to wire a Leviton 3 rocker/4 function switch to a fan with fan/heat/light/night lt. There are 3 colored wires out of the back red,black,blue and 2 load screws.
If the two load screws are connected with a tab that is the power in side. The color wires are the load.
11/3/2017 1:27:47 AM • Leviton... • Answered on Nov 03, 2017
Leviton Decora Gray Rocker 4-Way AC Quiet Switch Logo
11 questions posted
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Leviton Electrical Supplies
Most Popular Question
4 way switch wiring
  • Electrical Supplies
