20 Most Recent Goldstar R1203 Air Conditioner Questions & Answers
0answers
What settings will give the most cold air?
cool max If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
1/21/2015 8:36:06 AM • Goldstar R1203... • Answered on Jan 21, 2015
What does dry setting mean
humidity removal If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
1/21/2015 8:24:16 AM • Goldstar R1203... • Answered on Jan 21, 2015
My ac unit will not stay on with a timer pluged into it
remove timer
4/14/2013 1:22:54 PM • Goldstar R1203... • Answered on Apr 14, 2013
2answers
My window ac looks like
Shirley, it's just a harmful mist. This usually occurs on hot, high humidity days. Keeping the air intake filter clean, will help to reduce it.
I hope this helped you and thanks for choosing FixYa.
8/10/2011 9:54:32 PM • Goldstar R1203... • Answered on Aug 10, 2011
I have one but i
here is a link yo the Owner's/Service Manual for your Goldstar R1203 AC Unit.
You may download and print it for future reference.
http://www.appliancefactoryparts.com/content/pdfs/119247-8.pdf
I hope this helps you.
7/18/2011 5:16:06 PM • Goldstar R1203... • Answered on Jul 18, 2011
I plugged it in and the fan does not work. it
Try to take the front off of the unit. You can reach your hand inside the blower chamber and reach for the blower cage. Try to turn it by hand, it may possibly have a dirt dobber nest or something lodged into one of the fan blades keeping it from turning. Sometimes on the newer units, the motors are so weak, they need a little help starting if they have been sitting a while. Hopefully this will solve your problem.
6/21/2011 9:11:26 PM • Goldstar R1203... • Answered on Jun 21, 2011
How do I close the vents on my Goldstar air
Wall mounted a/c is having vent close in remote it self. In remote press in any one name of the following. vent/air flow/sweep/swing. And also after switch off by remote wait for 30 seconds to get automatic close vent.
12/14/2010 2:07:22 AM • Goldstar R1203... • Answered on Dec 14, 2010
Is it normal for my
i am assuming you mean it is like a cloudy color, it has to do with the humidity and the coolness of the air from the a/c. This is a common occurence in an automobile. Hope this helps Tim
8/10/2010 11:24:27 PM • Goldstar R1203... • Answered on Aug 10, 2010
Knob control stems cracking
hello. when the stems crack, it is generally due to age and drying out of the plastic. you may be able to get new knob controls at your local appliance store. You can also do a repair with some clear one minute epoxy. J.
6/24/2010 3:07:05 AM • Goldstar R1203... • Answered on Jun 24, 2010
The power cord on my goldstar R1203 gets super hot
I would have the unit checked by a Service Tech and would not run it (the AC) until it was fixed.
This could be a dangerous situatiion especially if the breaker doesn't trip.
6/11/2010 4:35:17 AM • Goldstar R1203... • Answered on Jun 11, 2010
Is it good to close the vent or have it open
The vent will bring in outside air while running. If you are use the cooling keep the vent closed for the best performance.
If you are just using the fan only for air circulation and it is mild outside you can open the vent for fresh air to be pulled into your home.
5/30/2010 5:48:39 PM • Goldstar R1203... • Answered on May 30, 2010
Compressor not working
If you are kinda handy you can check the capacitor the compressor side sounds like from your description is bad. Cheap part to replace in a small place to repair.
5/6/2010 9:21:12 PM • Goldstar R1203... • Answered on May 06, 2010
2answers
Everything works on the unit but it does not get cool
You can purchase a bullet piercing valve port to install the refrigerant your unit takes. Refrigerant is available; however, some are much more expensive than others and it is necessary to use the exact type of refrigerant your unit was designed for. The prices of R12 and R22 are astronomical. If your window unit uses either of these two refrigerants, you would be well advised to invest your money in a new unit rather than repair what you have.
Though this is probably not news you wanted to hear, I hope the information is very helpful to your decision-making, moving forward. :-)
5/4/2010 7:43:31 PM • Goldstar R1203... • Answered on May 04, 2010
2answers
Ac turn on and cold air comes out for a few
its a compressor problem. compressors are not user serviceable. You need to contact an air conditioner technician for this problem.
7/20/2009 6:32:23 AM • Goldstar R1203... • Answered on Jul 20, 2009
Getting a/c out of window?
Fix It was a waste of time!!!
After recieving four emails from Fix it, purporting to have collected solutions offered by "experts" -- each turning out to be solicitations for paid services and memberships but offering no solutions to our problem -- we decided to tell everyone we know that Fix It is not worth trying.
Fix It is either an outright fraud or should police the profiles and accounts on their site.
REMOVE MY MEMBERSHIP.
6/21/2008 11:40:10 AM • Goldstar R1203... • Answered on Jun 21, 2008
Ac unit barely runs
Hi, Sounds like the lightning got your unit too. You could run an extension cord from another plug temporarily just to make sure the plug isn't the problem but I think its time for another unit. Good luck. May want to contact you home owners ins company if there are more appliances blown. kstfas
8/28/2007 11:38:24 PM • Goldstar R1203... • Answered on Aug 28, 2007
3answers
How to clean a Goldstar 6004 air conditioner
https://www.thespruce.com/how-to-clean-a-window-air-conditioner-unit-5191162
8/30/2023 2:22:32 PM • Goldstar Heating... • Answered on Aug 30, 2023
Goldstar R1203 Air Conditioner Logo
26 questions posted
Top Goldstar Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Goldstar Heating & Cooling
Most Popular Question
  • Heating & Cooling
