20 Most Recent Goldstar R5050 Air Conditioner Questions & Answers
My ac unit fell out
Typically there is a wiring diagram stamped right on the unit.just have to find If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
7/14/2017 1:41:13 PM • Goldstar R5050... • Answered on Jul 14, 2017
How do i get the freeon in the ac
Air Conditioners don't 'Use' freon per se. A common fallacy is the thinking that if "It's not getting cold, then it needs freon." If your unit lost freon, it has a leak and adding freon will only be a very short term fix.
If you're certain that you need freon, you'll have to take the unit to a certified HVAC technician. EPA regulations make it nearly impossible for the average handyman to service A/C units, since the freon must be handled in a very specific way with equipment not generally available to the average owner, was well as R-12 freon gas which can be bought only by licensed HVAC technicians.
However, there are many other problems that are far more likely to be the cause of no cooling than loss of freon. It could be something as simple as dirty condenser coils (you'd be surprised how common it is that a simple cleaning of these coils will 'fix' a non-working window A/C), to a defective thermostat switch, to other defective switches/controls.
Unless it's a very obvious leak, I always suspect a loss of freon LAST on my list of possible cause of non-cooling in these units.
11/14/2014 7:46:14 PM • Goldstar R5050... • Answered on Nov 14, 2014
0answers
Wiring for Goldstar R5050 window A/C
Yes I accidentally drop my Gold Star Model #R5050 out the window while installing it. I opened it up and the two(2) white wire are off and I don't know were they go. I try to connect the to the empty terminals and I got a spark out of the outlet. Can you please help me....
7/1/2013 2:14:38 AM • Goldstar R5050... • Answered on Jul 01, 2013
My GoldStar R5050 air
Is the compressor running?
8/3/2011 3:35:25 AM • Goldstar R5050... • Answered on Aug 03, 2011
Can you add btu or something to the cooler so it
As much as you and i might like to it is not possible. But you can check you filter and see that its clean that will improve the air flow acroos the coils
7/23/2011 1:14:01 AM • Goldstar R5050... • Answered on Jul 23, 2011
With the unit running, the unit sounds as if water
This is usual But be certian that the unit is tilted enough also check filter and clean it while your at it . then check drain . you might have some dirt around the drain . if so clean it and add a bit of clorox a tiny bit ony to the drain let me know
7/22/2011 11:12:59 PM • Goldstar R5050... • Answered on Jul 22, 2011
It has been blowing warm air. It will blow cold
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
7/12/2011 2:14:56 AM • Goldstar R5050... • Answered on Jul 12, 2011
Hi, I have Gold start
your problem is cable try insulate with electrical tape the damage portion of your aircon cord if you want to replace cable please state how much horse power and voltage use.
2/6/2011 5:56:18 AM • Goldstar R5050... • Answered on Feb 06, 2011
What if the air conditioner is not dripping the
It could not be charged properly - is it cooling?
Some units sling the condensate up on the condensor coil and it evaporates.
Or, You have a low humidity conditon.
10/13/2010 5:46:03 PM • Goldstar R5050... • Answered on Oct 13, 2010
Water is coming in through
Tilt outward using a level 1/4 bubble
8/9/2010 3:40:08 AM • Goldstar R5050... • Answered on Aug 09, 2010
My AC window unit not getting cold i supose need
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
7/12/2010 2:25:56 AM • Goldstar R5050... • Answered on Jul 12, 2010
Goldstar R5050 Air Conditioner Logo
49 questions posted
Top Goldstar Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Goldstar Heating & Cooling
Most Popular Question
goldstar r5050 air
  • Heating & Cooling
