20 Most Recent
Canon Laser Class 830i Plain Paper Fax Questions & Answers
Can't receive large faxes
This is not a UK model but the same principles apply. When you receive a fax it is stored in the memory until the whole page is received, then it will start to print. The memory is not split so if you have a lot of faxes to transmit stored in the memory, they will gobble up the memory and reduce the size for receptions to be stored in. Check to see what is stored and delete them to free up memory. If this does not resolve the issue then the machines memory will need to be cleared by the service mode. As I don't know the UK version I cant advise any further.
Our RX report for our Canon 830i fax machine lists
This error usually means you have a phone line problem.
You need to try to increase your transmission level, or check the line equalization. It could also be a problem with an echo on the phone line.
Photo copys are intermittently coming out black
you need to watch the exposure lamp under the glass . see if it goes out during a copy run. if so you may have a bad lamp, wires, invertor or pcb. if it does not go out you may need a drum, chagre replacemnet or developer. you may need a tech to look at it.
