20 Most Recent
Canon imageRUNNER 2010F Copier Questions & Answers
My Canon iR 2010 is
thanks a lot , i can clear by your solution and i press *function and # and arrow to #7 press ok and #4 printer reset press ok
1/12/2014 3:28:43 AM •
Canon...
Answered
on Jan 12, 2014
Need to clear printer memory
It sounds like you have a problem with your network and or hub. I would look at that first, it's not the copier. Good Luck
10/8/2012 8:41:22 AM •
Canon...
Answered
on Oct 08, 2012
Error Code E004
there is heater problem and voltage also ....reset ur printer...(press @ (add. star) then # (hash) go to printer using arrow then press okselect reset using arrow press okif problem continue ...open the left cover and remove the heater out...replace the thermister or complete heater
12/1/2011 2:29:40 AM •
Canon...
Answered
on Dec 01, 2011
E000 error
this is error for fixing temperature fault due to faulty heater lamp or thermistors.
If the trouble is temporary you can reset it in service mode.
Procedure:
Press the user mode key ( * ) and ID key on keypad ( # ), with help of arrows go trough the service mode to CLEAR and press OK, choose ERR and OK.
After clearing if the error is still on, you need to change the fixing unit. Because of legal and safety regulations, replace the whole fixing unit with new one from original manufacturer Canon.
Eaven if it's only lamp or thermistor trouble, replace the complete fixing unit!
Hope that helps!
9/17/2011 9:42:42 AM •
Canon...
Answered
on Sep 17, 2011
CANON IMAGERUNNER 2010F HAS A
The E100 error code has to do with the laser. But in this case, it may be just that the drum ahs to be replaced. How long has it been since it was replaced? They are cheap and easy to put in.
7/15/2011 4:11:52 PM •
Canon...
Answered
on Jul 15, 2011
Won't print System Error E100
E100 means a beam detect failure of the laser that "writes" the image to the drum. There are 3 logical causes. The laser scanner unit has failed.Next down the list is the DC controller has failed.Last, the Image Processing Board has failed. The code indicates the laser is not coming on which would lead you believe that it would be the primary cause.The laser unit has a detector inside that looks for the laser and reports success or failure to the image processing board.The DC controller is resposible for turning on the laser and its ouput. That's why there are at least 3 variables.
7/10/2011 1:28:01 PM •
Canon...
Answered
on Jul 10, 2011
MY IR CACON COPIER 2010
This is a problem with the fuser assem bly and will most likely have to be repaired by a Tech. Not getting hot.
6/21/2011 8:20:38 PM •
Canon...
Answered
on Jun 21, 2011
I have canon IR2010F copier
there are two locking handles for the adf on either side of the cover of adf
i am sure one of them is broken or disfigured that why when u press it the adf works.i dont think this spare part is available u have to use ur own creative skills to make it through melting plastic to make a hook for that side
6/6/2011 3:16:15 AM •
Canon...
Answered
on Jun 06, 2011
I AM TRYING TO FIND
copy the front page and when it prints, put the copy in the paper holder backwards and copy the back page. This new copy will have the front page and back page on the same sheet of paper.
10/7/2010 8:50:06 PM •
Canon...
Answered
on Oct 07, 2010
I get an Error E000 on IR 1600
hi you have problem with fuser unit may be some time this problem came when yours copier is 220v and you have put in 110v if u dont then u have problen in fuser unit may be broken lamp or thermal fuse thanks
5/12/2010 10:06:51 PM •
Canon...
Answered
on May 12, 2010
