20 Most Recent Riccar 4812 Vacuum Questions & Answers
Replacing riccar 4812 hose
To replace just the hose unscrew it from the swivel attached to the back of the vacuum. The replace swivel insert screwdrivers into the tabs holding it to the body (from inside the dust compartment) to remove it, the new one snaps into place.
1/13/2015 3:33:18 AM • Riccar 4812... • Answered on Jan 13, 2015
Replacing off switch
Remove the screw holding the handle to the body of the vacuum. Remove the screws to separate the parts of the handle to gain access to the switch.
8/11/2014 2:04:54 AM • Riccar 4812... • Answered on Aug 11, 2014
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
11/28/2013 2:00:47 AM • Riccar 4812... • Answered on Nov 28, 2013
0answers
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at [email protected].
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
2/24/2012 5:36:24 PM • Riccar 4812... • Answered on Feb 24, 2012
Riccar 4812 power cord is
Hi, My Name is Todd and I am going to try to help with this request.
I am trying to get you a service manual, so bear with me, but here is your owners manual
Your manual can be downloaded and printed by clicking on the link below:
http://www.riccar.com/ftp/whitepapers/4000-Series-Owners-Manual.pdf
6/26/2011 7:18:41 AM • Riccar 4812... • Answered on Jun 26, 2011
Won't come on when I plug it in. Does it have a
Greetings from GoVacuum,
Yes, the Riccar 4812 does in deed have a reset switch. Unfortunately some dishonest repair man will tell you at this point that your motor has gone, but 7-10 times it's the reset switch.
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I hink if it just stopped workint all or a sudden, it's prbably the reset switch.
If it's not, please email me or give me a call and I then diagnose the problem for you.
Chris Jones
GoVavcuum.com
[email protected]
1-866-468-2288
11/28/2009 6:59:51 AM • Riccar 4812... • Answered on Nov 28, 2009
My Riccar 1800 won't turn on all of a sudden.
Question edited for clarity and spelling of maker. Question moved from TX Watches category. Try the thermal reset again. When you are using the vacuum and then turn it off, the motor is hot and there is no cooling airflow. If the vacuum is close to cutting out through overheating that lack of air will trip it. If you have digital multimeter, you can check the thermal switch for continuity. https://www.google.com/search?q=Riccar+1800+won%27t+turn+on ..
1/9/2024 7:16:56 PM • Riccar Vacuums • Answered on Jan 09, 2024
Riccar 8850 Upright Vacuum Cleaner. I need a wiring diagram for it please?
Question edited for clarity and typo. There is no wiring diagram available https://www.google.com/search?q=riccar+8850+wiring+diagram There is a video though Or you could ask the maker?
Vacuum Cleaner Operating Instructions
Riccar http://media.riccar.com > 8000_Owners_Manual How to Replace the Agitator Belt. (Models 8750 8850 & 8800 only). Unplug the units power cord. Turn the unit over and remove the bottom plate as described in ... 13 pages ..
10/14/2023 12:42:34 AM • Riccar Vacuums • Answered on Oct 14, 2023
Riccar R-200 vacuum? Not working by the areas the has the foot pedal, maybe where the motor wires attach?
If your Riccar R-200 vacuum is not working in the areas where the foot pedal is located, it is possible that there may be an issue with the motor or the motor wires. Here are a few steps you can take to try and troubleshoot the issue:
  1. Check the power cord: Make sure that the power cord is securely plugged into the wall outlet and into the vacuum itself. If the cord is loose or damaged, it could be causing the issue.
  2. Check the foot pedal: The foot pedal is what activates the vacuum's motor, so it's possible that there could be an issue with it. Make sure that the pedal is not stuck or obstructed, and that it is moving freely.
  3. Check the motor wires: If the issue is not with the power cord or foot pedal, it's possible that there could be an issue with the motor or motor wires. To check this, you'll need to open up the vacuum and inspect the motor and wires for any visible damage or loose connections. Be sure to unplug the vacuum before attempting any repairs.
If you're not comfortable troubleshooting or repairing the vacuum yourself, it may be best to take it to a professional repair service or contact the manufacturer for assistance.
2/14/2023 5:28:10 AM • Riccar Vacuums • Answered on Feb 14, 2023
My Riccar brush will spin for a second and then stop spinning.
bad drive motor
7/16/2022 8:00:15 AM • Riccar Vacuums • Answered on Jul 16, 2022
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
1/4/2022 5:12:56 PM • Riccar Vacuums • Answered on Jan 04, 2022
Our handheld Riccar Gem R-4 stopped working. I looked and the bag was super clogged... oops. I cleaned it up but the machine won't turn on. Is there a fuse or breaker or ... is the motor shot?
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you will hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced. https://www.google.com/search?q=Riccar+Gem+R-4+thermal+fuse ..
5/20/2021 4:53:43 PM • Riccar Vacuums • Answered on May 20, 2021
Vacuums Logo
Popular Tags
15 questions posted
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Riccar Vacuums
  • Riccar Vacuums
Most Popular Question
reset button power
  • Vacuums
