20 Most Recent Riccar 8000, 8900 Series Metal Agitator Cover, Bottom Plate Assembly C Questions & Answers
If you remove three screws you can remove the assembly with the foot pedal. Look at how it is installed closely in the assembly, including the spring, shaft and pedal. Disassemble it and install a new foot pedal exactly the same way you took it apart.
Riccar 8000,... | Answered on Mar 08, 2016
Start by replacing the belt and make sure the clutch switch is in the correct position. If that doesn't solve it you should check the clutch in the brush roll to see if it is worn.
Riccar 8000,... | Answered on Aug 11, 2014
Slide a small screwdriver beside the wheel and rotate it to push up on the axle holding the wheel in place
Riccar Vacuums | Answered on Oct 23, 2018
Your 8955 could be up to 17 or 18 years old. If yours is old or has been heavily used it may have a wiring short somewhere. The screw holding the handle in to the body of the vacuum might be loose which can cause the handle to not full engage the switch. Try wiggling the handle back and forth to see if it causes the power to turn on and off. Tighten the screw holding the handle in.
If the nozzle housing is restricted from pivoting freely by wear or dirt or debris the nozzle may not go all the way down when the handle is reclined back into the vacuuming position. Inspect the pivot area closely.
you will need to get the whole base plate look on ebay
Riccar Vacuums | Answered on Sep 06, 2018
Start by checking the suction opening by the brushroll. Then remove the screws and take the nozzle cover off. Remove the cover to be able to inspect the impeller for clogs or debris. Pull the motor if necessary to gain access to the lower end of the suction tube/handle.
Riccar Vacuums | Answered on Sep 04, 2018
Your 8650 is likely about 30 years old. It may not have a reset switch. If it won't run it may need a new cord or switch. If it's in good shape it may be worth having it looked at by your local Riccar dealer.
Riccar Vacuums | Answered on Aug 05, 2018
Lay the vacuum on the floor upside down, remove two screws to remove bottom plate to get to the lightbulb
Riccar Vacuums | Answered on Jun 02, 2018
Hello, Refer to page 9 of this owners manual. It involves removing a plate on the bottom.
http://media.riccar.com/manuals/8000_Owners_Manual.pdf
Remove the screws holding the cover that holds the handle in to remove the handle. Reverse the procedure with the new handle.
Riccar Vacuums | Answered on Apr 28, 2018
Your 8955 could be as old as 18 yrs. Try tightening the screw holding the handle in, it could be loose allowing the handle to move back and forth enough to keep the switch from activating.
If it's an older vacuum or is used heavily it could have cracks in the body where the handle screw attaches or some damage inside the vacuum body where the handle bottom goes into.
If that doesn't help, Remove the bag door, remove the screws at the top to remove the cover to gain access to the area where the switch and wiring is located to inspect for the cause. When you push the lever at the top of the handle a lever going down activates the switch. It doesn't take much play in the handle to make the switch go on and off.
Riccar Vacuums | Answered on Apr 22, 2018
Fixya cannot supply Riccar vacuum parts.
Riccar Vacuums | Answered on Jan 22, 2018
I will likely save money by having it checked out by your local Riccar service center. A Brilliance can last a long time and work great but like any quality vacuum should be properly serviced every year or two depending on use. A qualified service technician knows what to look for and what your vacuum needs to work properly.
Riccar Vacuums | Answered on Jan 21, 2018
Your m
2150 L is likely 25 to 30 years old. The first Riccar vacuums were made in Japan. Your was likely made in Taiwan. Production of most models was brought to St. James, MO 20 years ago. Filters, bags and some parts are still available from your local Riccar dealer, or from ThatVacGuy.com
Riccar Vacuums | Answered on Dec 20, 2017
I'm not sure if that model does but if so it will be on the back of the vacuum in the area of the motor compartment.
Riccar Vacuums | Answered on Nov 23, 2017
Riccar 8000, 8900 Series Metal Agitator Cover, Bottom Plate Assembly C Logo
2 questions posted
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
rebecca curry
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Riccar Vacuums
  • Riccar Vacuums
Most Popular Question
need tube showing me replace handle
  • Vacuums
