20 Most Recent Kenmore 80 Series Heating Element - 134035859 Questions & Answers
How do i light the pilot light
Dryers do not have pilot light, you either have a spark or a hot surface igniter. Both are electrically activated.
10/16/2015 8:47:06 AM • Kenmore 80... • Answered on Oct 16, 2015
My gas kenmore 80 series is not heating?
ELECTRIC Dryer no heat or little heat: Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it) Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective. Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220, Check the thermal cut off, the cycling and the hi limit thermostats. For continuity or OHMS. If no ohms or resistance they need replacement. Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet. Test with a meter at room temperature and it should show continuity.
3/31/2015 1:19:42 AM • Kenmore 80... • Answered on Mar 31, 2015
No heat
Hi abbey Here are a few things to check: ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT. Check to make sure you are getting full 220 Volt power to the dryer, if you are then:Check your WiringOften the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.Check the Door SwitchIf the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat. If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.DO THE FOLLOWING TEST:To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.If you do not have a volt/ohm meter then:DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.A vent clogged with lint can cause it to overheat. Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.If the vent's clogged, that new element can burn out very quickly. For video and pictures on how to replace a generic element go to the following website: davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm Please take time to rate meBud
4/13/2013 2:01:41 PM • Kenmore 80... • Answered on Apr 13, 2013
Won't get hot
1/13/2013 10:30:36 PM • Kenmore 80... • Answered on Jan 13, 2013
Dryer stops turning
What is your model number is then we can get started then
1/4/2013 1:21:23 PM • Kenmore 80... • Answered on Jan 04, 2013
All of the fuses check out element is good all conections good but no heat
There are 5 switch-like elements in series with the heater element, according to one diagram I found (Google "kenmore 80 dryer wiring diagram"). If any of these is open you won't get heat. If you're handy with a VOM, it's any easy problem to track down. Start at the element -- you should see 240VAC across it. If you do, the element is bad. If you don't, check across all the other switch-like things. You should read 0VAC across each of them if they're closed (good) or open (bad). It's a relatively easy matter to find a single open element, slightly more complicated if there are several. Or, start across the 2 240VAC line legs. You should read 240VAC; if not, your problem is outside the dryer (circuit breakers DO fail). If so, there is an open somewhere in the circuit preventing current flow. Move one of your VOM test leads through the circuit from that 240VAC leg all the way around to the other leg. It will continue to show 240VAC until you pass over the open element (a switch-thing, a bad piece of wire (unlikely), or the heater element), at which time it will show 0VAC. When that happens, the problem is in the element you just passed over. If you're lucky, it will be an easily-replaced part.
9/24/2012 12:40:37 PM • Kenmore 80... • Answered on Sep 24, 2012
2answers
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
4/23/2024 11:52:33 AM • Kenmore Dryers • Answered 2 days ago
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Is it possible to reverse the direction that the door opens on Kenmore Elite Quietpak 4?
Yes, it looks like you can. Don't forget though that you have to get inside and move the door switch. https://www.google.com/search?q=Kenmore+Elite+Quietpak+4+reverse+door ..
1/26/2024 12:16:00 AM • Kenmore Dryers • Answered on Jan 26, 2024
Kenmore ELE-2406028 Laundry Dryer. Help with door switch replacement.
It is an easy enough job. The videos show how. The parts are here https://www.google.com/search?q=Kenmore+ELE-2406028+door+switch ..
1/2/2024 4:11:27 AM • Kenmore Dryers • Answered on Jan 02, 2024
8546206 tech sheet
What is the question? Do I have the tech sheet? Yes I do.
12/17/2023 6:48:07 PM • Kenmore Dryers • Answered on Dec 17, 2023
Looking for age of Kenmore gas dryer Model 110.77741600
The are various idea here.
I have model and serial #s for my washer/dryer. What year ...
iFixit https://www.ifixit.com > Answers > View > I+have+m... Apr 3, 2017 - I have a Kenmore washer and dryer. I have the model #s and serial numbers. I need to know what year ( how old are my appliances?) of the models. 4 answers · Top answer: Erin Morrissey , How to find out the manufacture date of a Kenmore washer or dryer by the ... How old is my dryer? - Kenmore 110 Series ... 2 answers Mar 11, 2022 How old is my kenmore washer/dryer combo? - iFixit 2 answers Aug 4, 2018 help me find out how old this washer is - iFixit 2 answers Sep 29, 2021 What is this dryer model number? - Kenmore Elite ... 2 answers Jul 18, 2016 More results from www.ifixit.com Missing: 110.77741600 ‎' Show results with: 110.77741600
Can you tell me the age of a dryer from the model or serial
JustAnswer https://www.justanswer.com > Appliance Repair May 19, 2023 - Can you tell me the age of a dryer from the model or serial # Kenmore 600. Model is 110 78652700 serial is - Answered by a verified ... 1 answer · Top answer: Good afternoon. My name is ***** ***** I'll be assisting you with your appliance today. Please ... Missing: 110.77741600 ‎' Show results with: 110.77741600
12/15/2023 2:51:24 AM • Kenmore Dryers • Answered on Dec 15, 2023
2answers
Installation manual for kenmore dryer model 110.62872102
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Kenmore model by clicking the link below. 11062872102 KENMORE RESIDENTIAL DRYER Manual Sears PartsDirect You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/appliances I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/28/2023 8:45:45 PM • Kenmore Dryers • Answered on Nov 28, 2023
2answers
Kenmore dryer won't start
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=kenmore+dryer+will+not+start
11/18/2023 8:25:14 AM • Kenmore Dryers • Answered on Nov 18, 2023
How to change time settings on a Kenmore series 600 electric dryer
Follow these simple steps:
  1. Turn on the dryer by pressing the "Power" or "Start" button.
  2. Use the "Time Dry" or "Timed Dry" button to select the desired drying time. Press it repeatedly to increase the time in one-minute increments or hold it down to scroll through the time options more quickly.
  3. Once you've set the desired drying time, press the "Start" button to begin the drying cycle with the new time settings.
11/8/2023 8:37:58 AM • Kenmore Dryers • Answered on Nov 08, 2023
My Kenmore just stopped while heating something... shows No power... any ideas?
Your Kenmore Dryer has a number of things that can cause this. Most basic, the house breaker has tripped. The timer or electronic mainboard has failed. The element has failed One of the 3 heat regulation devices has failed or tripped out, one resets itself, the thermal fuse has to be replaced. 'make model (what it is)' in all questions please. ..
11/5/2023 12:45:42 AM • Kenmore Dryers • Answered on Nov 05, 2023
Kenmore 80 Series Heating Element - 134035859 Logo
12 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
light pilot light
  • Dryers
