20 Most Recent
SanDisk 4GB Memory Stick PRO Duo Memory Card Questions & Answers
When I insert my card I get a message. Reinsert
I'm currently having the exact same problem and my files cannot be read by a card reader either. I have 500 photos of my holiday in India on there so I'm desperate! Did you find a solution?
When i try to format the memory card, it displays
There is a tiny slide switch on the side of the memory card if you look on carefully. Slide it accordingly as indicated to unlock, this is provided to prevent accidental erasure of important data in the card.
Not able to view pictures
Don't know about cam (was there a software disk to install?).
As far as the reader goes you reader must be compatible with both devices.
Hope this helps
Will not allow me to view pictures I just took
Try to recover what is left on the memory stick with TestDisk on a pc.
Note, download the windows version and not the dos/windows version, the
dos/windows version is for windows 3.11 and lower.
http://www.cgsecurity.org/wiki/TestDisk_DownloadTry to fomat the card afterwards if this does'nt help at all try another card in
your camera, if the other card works replace your other card else get te camera autorized repairs man.
Succes.
Wont autorun! not formatted?
Yeah there is an issue with the format of the card, you would need to format the card before you use it ever in your camera or pc.. The thing is people think there already formated and the camera sotred the pics on it without a format or with a format of its own that is not recon. by the computer. Make sure you format using FAT and not NTFS or any other format to allevaite further issue's.. I hope this helps you and Thank you for using Fixya.com please rate this soution we do not get compensated for free questions however we look for good ratings.. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SanDisk memory stick pro duo 4GB not reading
does ur camera recognize ur mem stick if yes then copy all ur pics to a computer then format it an insert the stick to ur cam and u can copu it again to the stick. check it out.
Deleted images
There are plenty of undelete tools around.
Try Tokiwa DataRecovery http://tokiwa.qee.jp/EN/dr.html, it is a free tool.
Jules
Sandisk ultra write protected
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjijK-2oOeCAxX2k4kEHZN0CnEQrAIoAHoECCQQAQ&url=https%3A%2F%2Fforums.sandisk.com%2Ft%2Fremove-write-protection-from-usb-drive%2F33510&usg=AOvVaw3A01NeRgbLmAWvj17rGaBA&opi=89978449
11/28/2023 5:48:51 PM •
SanDisk...
Answered
on Nov 28, 2023
ACCIDENTLY DELETED MY LOCK
Just google "rescue my files"
Lots of sites are offering software to recover deleted files, or even files from a formatted drive.
Be aware, if you did write anything on the drive after formatting, it will decrease the chance of and the amount of files you can rescue.
Most sites offer a trail version wich you should use first, to see if there is still something to rescue. To my knowledge there were some good freeware programs, but not sure they are still there. I use a paid version, since I deleted a drive by accident
1/12/2020 2:42:20 PM •
SanDisk...
Answered
on Jan 12, 2020
