20 Most Recent
Kingston 1GB PC2700 DDR DIMM Memory Questions & Answers
I have got a compaq presario 6000 series pentium 4
the bios might be seeing it but windows might not, the possibility exists that windows is not able to view the full amount of ram installed try this. go to the start menu > accessories > system tools option and look for the system information tool, this will tell you more about the ram installed, note: windows dose on occasion report the wrong amount of ram when their is a 64 bit os installed or their is a 64 bit system
Its a NVIDIA nForce2 with dual channel DDR &
From the information you sent, I can't figure out the exact make & model of your motherboard, but I would guess that it supports a maximum of 2 GB of RAM. So, I would suggst you try to install 2 RAM modules, each of them 1 GB in capacity & see if this works.
From my previous experience, most motherboards with only 2 slots for RAM modules support only a maximum of 2 GB RAM total.
PC RAM
This refers to the data width and chip configuration. 64*8 is an 8 chip 512MB module. (8 components @ 64MB each) 32*8 is an 8-chip 256MB module. (8 components @ 32MB each), etc.
Dell dimension 4550
Dell has a habit of using proprietary memory in their machines, if it isn't proprietary you can near guarantee that cheaper memory sticks will not be recognised.
Play safe and use the memory configurators at crucial.com and newegg.com
I bought two DDR2 1gig sticks at crucial yesterday for $50.00 for both with free shipping.
Warranty or exchange??
hi
as u have identified the problem, pls take the defective to point of purchase for replacement.
if still a problem than to kingston for replacement. kingston gives life time wty for memory and u are eligible for new replacment.
let me kow if still a problem
regards
