20 Most Recent
AT&T LG CU720 Cell Phone - Silver Questions & Answers
I need the unlock code for lg cu720
For the best results on this issue, please contact AT&T technical support for a solution to this trouble.
Thanks for your interest in FixYa.com
LG Shine Bluetooth problem with motorola S9 stereo headphones
all you gotta do is disconnect the device in the bluetooth menu and reconnect that way the lg shine will recognize the right ear piece. at&t wouldnt release a product if it didnt work. the only problem is that at&t didnt say it in there instruction booklet
Set password for text messages
unfortunatly you cant just lock one thing on the shine. but you can lock it all at once u can set it so if you turn it off everything is locked and only can be looked at with a password,
HOW DO I HARD RESET MY PHONE
To perform a Master Reset
- This will clear out user settings, profiles, etc from the phone. (This will delete all user files. Backup anything you want to save to another device. SD card, laptop, Dropbox.. etc.)
- Go to the Main Menu
- Select Settings
- Select Reset Settings
- Select Master Reset
- A prompt All settings reset to default. Continue? will come up
- Scroll to Yes then press OK
- Enter 0000 for the Security Code then press OK
Note that if the default Security Code has been changed, enter the new code.
- The Resetting Progress will go through to 100% and the phone will be Master Reset
- You will then begin setting-up your device again.. email, preferences, apps.. etc.
Reset alcatel
You can reset Alcatel phone using Master Reset Code. It will reset your phone, removing any security locks(except network locks) . To get the master reset code for free visit
Unlock-Free.com . They provide master reset code for some old model Alcatel phones.
How to make voicemail to text message
Assuming that the you want to have voicemail messages automatically transcribed and either emailed or SMS/Texted to you so you can read them...First, you would need to get the audio of the message to either an automated or human powered transcription service. Since none of the cellular carriers' voicemail systems are capable of that, the other option is to have unanswered calls diverted to a voicemail system that is capable of delivering an audio file via email. Fortunately, all of the major carriers (including AT&T in your case) offer call forward busy/no answer at no charge.Once you have liberated the message from the grip of the cellular carrier, you then need to find a service provider that can receive the audio file, rapidly transcribe it, then email and/or text it to the destination(s) you desire.Automated transcription is generally faster -maybe a couple of minutes- and cheaper -free to a few cents per message- but the accuracy can be laughable. Human powered transcription is a bit slower -maybe 5 to 10 minutes for the average message- and more expensive -maybe $0.20 to $0.50 for the average message-, but the accuracy is reliable.GoogleVoice is a good example for the automated/free option.www.TalkScribe.com is a good example for the human powered option.
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.1. Check if the sim is properly inserted.2. Turn off mobile phone3. Remove battery4. Remove memory card5. Remove sim card6. Check the copper pins of the sim if there are dirts stucked on it7. Ure clean cloth to wipe sim gently8. Wait for at least two minutes9. Gently and properly insert the memory and sim card10. Insert the battery11. Turn on mobile phone13. Check if you will still recieve insert sim error14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
