20 Most Recent
Airlink 802.11G Wireless 4-Port Router (rt210w) Questions & Answers
What is the default password
Unless your Routers Manufacturer provided you with a temporary user name and password you will need to contact Airlink to have them reset the password once again here is the phone number just in case 1-888-746-3238. If not Here is the Default User name and password Username:admin
Password:admin
Good Luck
I want to know how
Set security password so only those can connect who know the password.
For that follow below.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
We do not have a secure connection to our wireless
You could change and configure your router through its web interface. To access it, use
http://192.168.1.1 on Internet Explorer, and enter 'admin' for the password.
- Go to Wireless LAN Security tab.
- Select WPA-PSK on Network Authentication.
- Enter a password that you want for your wireless network on WPA Pre-Shared Key (minimum characters is 8).
- Set Data Encryption to TKIP.
- Apply settings.
You should now reconnect your wireless computers to your network and enter the WPA Pre-Shared Key.
Can I use a router with a modem connection
erm dude your modem connection doesn't go in the router. It will either not fit or fry the router.
Anyways, You should have a cord with it that can go in the computer or (Maybe dsl box if you got one, then put the other cord into the computer)
If you got a cord that goes in the computer put it to share the internet connect (right click it on the modem connection and click properties then advanced then Share my connection (XP, VISTA, WINDOWS 7 ONLY))
Need to pull up my web browser in order to
Not actually, you only need to go to an address line. If you have your address line turned on on folders view, then that is consided a browser. To turn it on, go to any folder view, and click on view, then toolbars, and click on the address bar, and your set.
Thanks
Mark
Wireless Router stops working randomly
Unfortunetly this is a common problem with alot of wireless routers. for some reason they get locked up and don't refresh themselves and only solution is exactly what your doing until the manufacturer comes out with software that doesn't lock up every now and then
Router stops working every few hours
i think maybe its not your Router, did you check your internet provider, because they were there line have a problem of no connection... if your router working properly then it might be able to give you internet connection unless your internet provider have a problem, good luck!
