20 Most Recent Lexmark X4550 InkJet Printer Questions & Answers
I have orange light on wifi lexmark x4550. how do
take off the cable.
10/6/2021 2:21:33 PM • Lexmark X4550... • Answered on Oct 06, 2021
I have a lexmark x4550 printer and when I installed a new color cartridge the printer says the right cartridge is missing, what is wrong?
Has all protective tape been removed from copper contacts?
11/22/2017 12:09:28 AM • Lexmark X4550... • Answered on Nov 22, 2017
Wifi connection
What is the error message you receive when you try to connect it to Wifi ?
11/13/2015 9:12:37 PM • Lexmark X4550... • Answered on Nov 13, 2015
Lexmark X4550 - paper jam
My Lexmark did the same thing-if you can get in at the rollers to clean them that might help.
9/18/2013 4:57:08 PM • Lexmark X4550... • Answered on Sep 18, 2013
The AC/DC Adapter has died...no green light. Printer won't go. Where do I buy another new adapter.
Google the Internet for a power adapter for your model Lexmark printer. You will get various suppliers and prices.
1/31/2013 5:56:04 AM • Lexmark X4550... • Answered on Jan 31, 2013
Invalid ink lexmark
The printhead on the cartridge could already be damaged thus the need to replace the cartridge.
11/4/2012 8:23:53 AM • Lexmark X4550... • Answered on Nov 04, 2012
Join the clan I have several and several laptops all of them have stopped scanning with message cannot load application. I think it must be a windows auto security update that has zapped them all. I have tried reloads taking off firewall usb instead of wireless . All no joy. If you get a solution let me know pls.
10/29/2012 7:54:04 AM • Lexmark X4550... • Answered on Oct 29, 2012
I HAVE LEXMARK X4550 - when I open lexmark imaging studio i am told to use the controls on the printer. This is ok when i want to scan but if I want to use ocr option I am not given the choice. I am
There could be a problem with your printer software. Please insert your printer software installation CD into your computer hard drive. Execute the application to repair any possible corrupted printer software files.
3/13/2012 4:26:29 PM • Lexmark X4550... • Answered on Mar 13, 2012
Lexmark x4550 installed new cartridge a lexmark cartridge I keep getting alignment error. Take the tape off. There is no tape to take off since I already took it off. How can I fix this problem?
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
3/13/2012 4:24:10 PM • Lexmark X4550... • Answered on Mar 13, 2012
0answers
My x4550 will not let me use compatible cartridges
Hello!
23 and 24 cannot work after a refill. They are, as Lexmark calls them, "return program cartridges", not meant to be refilled, only used once.
You need to buy 23a and 24a or 34 and 35 cartridges. You can refill those and they work fine!
http://www1.lexmark.com/products/search/inktoner_finder.jsp?itemId=3925&catId=cat10003&trail=SRCH:Lexmark%20X4550:1002:cat10002:1006:Lexmark%20X4550&question=Lexmark%20X4550&_requestid=614147
7/23/2011 5:31:19 PM • Lexmark X4550... • Answered on Jul 23, 2011
Lexmark X4550 InkJet Printer Logo
150 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lexmark x4550 3 in 1 although
  • Office Equipment & Supplies
