20 Most Recent
Toshiba TECRA P5 T7100 1.8G VISTA / XP PRO PC Desktop Questions & Answers
All driver stopped working some time
I might advise you to reinstall the operating system of the computer there is something that is not working properly on the operating system, maybe there are some corrupted file in to it. or it a virus cause.
Toshiba washing machine model AW-DK1700WMM has turn on, beeps with error code EL then shut down within 5 seconds, how can I slove this problem?
To fix the EL error code:
* Make sure the door is completely closed and latched securely. A loose or broken latch can cause the error.
*Examine the door lock for any damage, dirt, or debris that could prevent it from working properly. Clean the area thoroughly.
* Turn off the washing machine, then unplug it for a few minutes. Plug it back in and restart it. This may resolve communication issues that trigger the error.
* Examine the wiring connections between the door lock system and the control panel. Faulty connections, such as loose or damaged wires, can disrupt communication and lead to the error message.
3/26/2024 1:48:19 PM •
Toshiba...
Answered
on Mar 26, 2024
How to fix tablet toshiba wt8-a
Ensure the cd rom is empty and the bios is set to boot from drive C first, then drive D.
If all in order and it still doesn't boot, try a system disc in the cd rom.
10/11/2023 4:56:30 PM •
Toshiba...
Answered
on Oct 11, 2023
Toshiba Strata CHSU40A3 no display or tone
If your Toshiba Strata CHSU40A3 phone system is not displaying anything and there is no dial tone, there could be a few reasons for this issue. Here are some troubleshooting steps you can try:
- Check the power source: Make sure the phone system is plugged into a functioning power outlet and the power adapter is working correctly. You may also want to try plugging it into a different outlet to see if that helps.
- Check the connections: Make sure all the cables and cords are connected properly. If the phone is connected to a network, check the network cables as well.
- Reset the phone: Try resetting the phone system by unplugging it from the power source and plugging it back in after a minute. This will help to clear any issues with the phone system.
- Check for any damage: Inspect the phone system for any physical damage, such as cracks or breaks in the casing or any loose components. If you find any damage, the phone system may need to be repaired or replaced.
If none of these troubleshooting steps work, you may need to contact a professional to diagnose and repair the issue with your Toshiba Strata CHSU40A3 phone system.
3/2/2023 5:37:06 PM •
Toshiba...
Answered
on Mar 02, 2023
What happened when Toshiba laptop shows alt+ctrl+del?
More commonly called 'control alt delete' or the 'three finger salute' it has two purposes. On a computer that is running, it brings up Task Manager and other instant settings like Switch User, or log Out. On a computer that is frozen, unresponsive, it does a hard rest and forces the computer to reboot.
2/22/2023 11:34:41 PM •
Toshiba...
Answered
on Feb 22, 2023
My toshiba laptop displays an expected error occured. Error Code 0xc0000034 during booting window
This error code 0xc0000034 usually indicates a problem with the boot configuration data (BCD) file on your Toshiba laptop.
The BCD file stores boot configuration information and is required for Windows to start up. The most common cause of this error is a missing or corrupt BCD file.
You can try the following steps and can try to resolve this issue:
1. Boot into the Windows Recovery Environment (WinRE)
2. Launch the Command Prompt.
3. Type the following command to rebuild the BCD file: "bootrec /rebuildbcd".
4. Press Enter and follow the on-screen instructions.
Note: If these mentioned steps do not resolve the issue, you may need to perform a repair install or a clean install of Windows.
2/3/2023 11:39:14 PM •
Toshiba...
Answered
on Feb 03, 2023
3Com Megahertz 3CXEM566 B 10 Mbps LAN+56K Modem PC Card Driver For Windows 98SE
https://www.driverguide.com/driver/detail.php?driverid=5372&si=9ea320d50a226c79eb7fb572e0673dd0
Try this link...I just confirmed that it does exist.
If you have any issues, Try using a Microsoft or a 3Com universal driver.
Last but not least, simply go on eBay for a vintage LAN card...that includes a driver CD that runs on Windows 98SE.
If you need further assistance, just reply after trying those possibilities.
I'm "A+" Industry Certified PC Repair Tech. If you can't find one in a box with driver disc, maybe I have some LAN cards.
Does this need an ISA or PCI slot?
12/13/2022 7:33:59 AM •
Toshiba...
Answered
on Dec 13, 2022
