20 Most Recent
Toshiba Satellite A135-S4527 Notebook Questions & Answers
I need driver laptop toshiba a135-s2276 for windows xp
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&rpn=PSAD6U&modelFilter=A135-S2276&selCategory=3&selFamily=1073768663
Copy and Paste the Link to your URL
6/14/2023 6:41:42 PM •
Toshiba...
Answered
on Jun 14, 2023
I just bought a brand new Toshiba Satellite P75-A7200. It won't play DVD's and keeps saying wrong area code...I live in Australia, bought the PC in Australia and am trying to play Australian DVD's but
hi, I think this may help. what you need to do first of all is change the default player for DVD's from Toshiba Video Player to Windows Media Player, cant remember off hand how to do that but should be in manual, but try this. go to windows control panel, select 'Default Programs' and click on it, then select 1st option 'Set Your Default Programs' a list of all programs will come up, look for Windows Media Player and click on it, then choose one of the options on the right. The top one sets as default, the bottom one allows you to set file types to open with the program. this should work as it is telling your system to launch that program for DVD's etc, If you cant find your control panel, simply click Start and type it in the little box that appears just above it.hope this helps
4/7/2020 12:35:44 AM •
Toshiba...
Answered
on Apr 07, 2020
I recently updated to windows
Sound like a performance problem. Did you try updating your video and sound
drivers?
You should also see if the Adobe Flash Player is properly installed as that is used for Youtube playback.
11/8/2019 2:17:28 AM •
Toshiba...
Answered
on Nov 08, 2019
Rent
why rent one pay it they quite cheap right now at least you will own but hey if you persist ask google "I want to rent a laptop" else come back here...............
8/4/2018 2:23:49 PM •
Toshiba...
Answered
on Aug 04, 2018
Toshiba satellite c660 stuck on windows splash
hi K Smith.
Here are some troubleshooting steps that may help in identifying the issue.
- Start by doing a hard reboot, remove the battery and unplug its AC adapter then press and hold the power button for 20 seconds and see if it will boot up.
- If these will not work remove the HDD then boot it up and see if it will still get stuck at the BIOS screen or not.
- If it doesn't get stuck on BIOS and boot onto a black screen that means it's the HDD that is faulty.
- If it does get stuck on BIOS even without the HDD that means it's the motherboard that is faulty.
- Last trick you can try is to remove the CMOS battery for a second then put it back in.
- If all these will not work you'll need to send it for a repair if its still under the factory warranty
or.
1) Unplug the power cord --> Remove the battery --> Hold the power button for
60 seconds --> Connect the power supply then try to switch ON the laptop and
later put the battery back into the laptop.
2) If the problem still exists then get it checked out.
or read up some more at this link.
Toshiba satellite c660 stuck on windows splash Google Search
12/8/2017 10:43:07 PM •
Toshiba...
Answered
on Dec 08, 2017
My Toshiba Satellite A215-S7428 seems
It could be a sympton of display cable failure or the display has failed, try plugging into an external source such as a monitor or tv and then try booting, if you get a display then it is the notebook screen or cable that may be faulty, hope this helps.
Keith
8/6/2017 8:19:51 PM •
Toshiba...
Answered
on Aug 06, 2017
Restore windows
Did you reformat the hard drive? Try to turn off your computer and re-do your setup
12/1/2016 12:54:14 PM •
Toshiba...
Answered
on Dec 01, 2016
