20 Most Recent
Frigidaire GLEB30T8A Electric Double Oven Questions & Answers
How do I check heating elements?
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
Frigidair double oven electrical problems
Good Afternoon Friend,
I understand you are having electrical problems with your Frigidaire double oven, model# GLEB30T8A. I also see that this is the third time you have had a repairman out to reconnect exposed wires in your 2 and a half year old appliance. I suggest contacting the manufacturer directly. They might have some advice or might be able to point you in the right direction to having your double oven repaired for good. Hope this is helpful.
-Best Regards-
WP
GLEB30T8CSA upper oven baking element has no power
It may be you have a bad element. If you remove it and have a volt meter you could check a the socket for power. Also if the upper and lower elements are the same change the working one to the upper oven and see if it works. If it does you need to purchase a new element. If there is no power to the upper oven you may have a bad control ora broken wire behind the panel. I would advise you to turn off the power to the oven before pulling or changing any componets.
Oven alarm keeps going off
Hello, Thank You for using FixYa. I will be helping you today.F8 is a failed door lock.Try turning the power off for ten minutes and back on sometimes this will fix it,If not you may need to replace the lock after checking it to see if it failed.
Thank You and please rate my answer if it was helpful..
My baking element burned into. can my oven work
I don't know if the broil element will work with the thermostat -- it's usually run full on. You could experiment and see, but the oven will not work correctly with just that element. You're used to baking with heat from the bottom and there is a difference. You might get away with it for pizza and meats -- MAYBE. But, even if it does work with the thermostat, do not try to bake with it unless you plan ahead to throw whatever you're baking away. Cakes, pies, etc. will be ruined with hea from the top. Replace the element -- they're not too expensive and they're easy to change. Just turn the power off first!
We have a Frigidaire Model
I replaced the relay board for the top oven (the one with thetransformer) and it works properly now. My issue was only for the topoven so you probably have to replace both relay boards since both ovenshave only the top element working.
318022002 is the part number for the relay board with transformer318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason. The boards are on the top of the oven, I was able to pull out theoven about 75% of the way out of the cabinet and easily get to theboards. Just unplugged the connections and plugged them into the newboard. To get the oven out there are two small screws that go intobrackets inside the top oven door. Highly recommend taking the doorsoff the oven to pull it out, much easier to work with. NOTE: On my old board I noticed one solder joint that was burnedout and I since I already had the new board I just replaced but youmight want to check that first and see if just a solder fix gets youworking again before you spend $$ on a new board.or try this
Most likely the thermal fuse is out for the top oven, your will have toremove the unit from the wall in order to test and replace parts. Thethermal fuse part # is AP2126993. If you need to see a parts breakdowngo to searspartsdirect website
Fire Mondel # PLEB30T9FC
very possible hat the element is no good, does it look physically burned???? if so replacing the elemnt is the only option,2 screws and 2 wiredis all, simple to replace, unplug/disconnect power first,,, the wires are always live to the elemnt!!!!!!!
My frigidaire ovens broiler came on, on high, when i was baking at a very low temp (170).
If your Frigidaire oven's broiler unexpectedly turned on while you were baking at a low temperature, it could indicate an issue with the oven's temperature control system. Here are a few possible explanations and troubleshooting steps:
- Incorrect oven setting: Double-check that you have selected the correct oven function and temperature settings. Ensure that you have chosen the "bake" function rather than the "broil" function. Also, verify that the temperature setting is appropriate for baking.
- Malfunctioning temperature sensor: The oven's temperature sensor, also known as the oven thermostat, could be faulty. A malfunctioning sensor may send incorrect temperature readings to the oven control board, causing it to activate the broiler unexpectedly. Consider contacting a professional technician to inspect and potentially replace the temperature sensor if necessary.
- Control board issue: The oven control board, which regulates various oven functions, could be experiencing a malfunction. If the control board is sending incorrect signals to the broiler, it may activate when it shouldn't. Consult a professional technician to assess and repair the control board if needed.
- Wiring or electrical problem: Inspect the oven's wiring and electrical connections for any signs of damage or loose connections. Faulty wiring or poor electrical connections can cause erratic oven behavior. It's advisable to have a qualified technician examine the electrical components to ensure they are functioning correctly.
