20 Most Recent Panasonic KX-TG6021 Cordless Phone Questions & Answers
The handset display is bad. This part can not be replaced because it is molded to the chassis of the phone. Replace the complete chassis or the handset and that would solve your problem.
Panasonic... | Answered on Oct 12, 2016
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Panasonic... | Answered on Oct 09, 2012
Hello
The handset navigator key can be used
to navigate through menus and to select
items shown on the display by pressing (UP) (DOWN) (REVERSE) (FORWARD) buttons on the handset.
Adjusting audio volume
Press UP or DOWN button repeatedly while
talking.
The last settings of volume level will be memorized when you switch OFF the habdset. OK.
Panasonic... | Answered on Sep 07, 2011
Unfortunately, there would be no way to prevent the specific phone from getting hot.
Also, cordless phones are not rated for heat. I would recommend a high-quality phone.
Panasonic... | Answered on Mar 07, 2011
Sorry you can only make one headset as the base headset.
Panasonic... | Answered on Dec 24, 2010
when it asks for unlock press 0000. it will get unlocked... othere wise without lifting the handset press *#1234
Panasonic... | Answered on Dec 04, 2010
Try powering down every thing including taking the battery out of the headset. power it all back up and try it again. if that does not work most likly during the storm your base station suffered a fatal surge and it toast.
mj
Panasonic... | Answered on Aug 31, 2009
The handset may have unregistered from the phone. The instructions to reregister it are in the manual, but I'll list them here for you.
1. On the handset, press MENU 001
2. On the base unit
For models KX-TG6021/KX-TG6022/KX-TG6023
Press and hold LOCATOR until the IN USE indicator flashes.
For models KX-TG6051/KX-TG6052/KX-TG6053/KX-TG6054
Press and hold LOCATOR/INTERCOM until the IN USE indicator
flashes.
After the IN USE indicator starts flashing, the rest of the procedure
must be completed within 1minute.
3. Press OK on the handset, then wait until a beep sounds.
4. Press OFF on the handset.
Panasonic... | Answered on Aug 29, 2009
you have to make sure that all the cable are plugged in and the power cable is plugged in too..
Panasonic... | Answered on Apr 26, 2009
change the channels on the phone and reboot it
Panasonic... | Answered on Aug 31, 2008
Panasonic KX-TG6021 Cordless Phone Logo
44 questions posted
Top Panasonic Lands Phones Experts
Ekse
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Lands Phones
Most Popular Question
cordless phone gets hot
  • Lands Phones
