20 Most Recent
Amcor MD250 Dehumidifier Questions & Answers
Where, in the UK, can I obtain Amcor replacement parts?
the thermal break is there for a reason, the motor has overheated, if this was due to a towel or other item covering the unit great remove the the obstruction and replace the thermal break. however the major cause is that the bearings have dried up on the motor and it has started to seize, which means replacement.
My 320 is powered up and running but is not
low outside temp means low indoor humidity
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Manual for PLDM18E
go to: http://www.edocr.com/doc/8/amcor-dc800-dehumidifier-operating-manual You can download the manual and read how to set the controls.
5/1/2014 5:21:33 PM •
Amcor...
Answered
on May 01, 2014
Filter frozen
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not operating properly.
5/1/2014 4:48:13 PM •
Amcor...
Answered
on May 01, 2014
Frozen filter
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not opperating properly.
5/1/2014 4:47:43 PM •
Amcor...
Answered
on May 01, 2014
