20 Most Recent
Amcor AHD65 Dehumidifier Questions & Answers
I acquired used Amcor AHD65
You may still have some packaging materials left inside the unit. The plastic pan doesn't stay in side the bucket. It's used as a drain pan on the outside. Also, be sure the air intake filter is in place, is clean and there are no packaging materials behind it.
To extract more humidity, after checking all the things mentioned above. Lower the extraction level to 32 to 35%. Lower percentages means extraction of more humidity. (i.e.200% -35% = 5% drop in humidity).
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Manual for PLDM18E
go to: http://www.edocr.com/doc/8/amcor-dc800-dehumidifier-operating-manual You can download the manual and read how to set the controls.
5/1/2014 5:21:33 PM •
Amcor...
Answered
on May 01, 2014
Filter frozen
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not operating properly.
5/1/2014 4:48:13 PM •
Amcor...
Answered
on May 01, 2014
Frozen filter
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not opperating properly.
5/1/2014 4:47:43 PM •
Amcor...
Answered
on May 01, 2014
