20 Most Recent Amcor AHD45 Dehumidifier Questions & Answers
I have searched and searched and have not been able to find an Owner's Manual for your model Amcor Dehumidifier. I did discover that Haier and Fredrich both have similar models, So similar, I suspect Haier manufactured them. But, neither the Haier nor the Fredich's unit have any information concerning Error Code 2. Plus, the ratings for your Amcor model were not very good. Seems that Amcor is riddled with problems.
In any event, lets try to solve your problem. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and remove the water collection bucket and the air intake filter. Check the filter closely for significant dust and dirt buildup and clean it if necessary. Make sure the filter is thoroughly dry, before placing it in the unit. Leave the unit unplugged for at least 15 minutes or until the filter is dry. Then replace the filter, insert the bucket - making sure that it fits swaourely from top to bottom into the bucket holder. Plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout has allowed the unit's electronics to reset themselves and they reverted back to the original factory settings. If so, set the controls to your liking and the unit should start and run like it should.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Amcor AHD45... | Answered on Jun 17, 2011
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Amcor AHD45... | Answered on Jan 27, 2011
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Amcor AHD45... | Answered on Aug 17, 2010
A dehumidifier should blow cold air Carole. It takes in warm moist air, chills it, condenses the water out of the air and returns it chilled and dry to the room. That is the function of a dehumidifier. They often have the function of an air conditioner and blow cold air out of one outlet into the room and hot air out of the window via a venting hose. If yours is just a dehumidifier, it is working as designed
What were your expecting a dehumidifier to do?
Amcor... | Answered on Jan 15, 2016
go to: http://www.edocr.com/doc/8/amcor-dc800-dehumidifier-operating-manual You can download the manual and read how to set the controls.
Amcor... | Answered on May 01, 2014
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not operating properly.
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not opperating properly.
Amcor AHD45 Dehumidifier Logo
Popular Tags
5 questions posted
Top Amcor Dehumidifiers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you an Amcor Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
Amcor Dehumidifiers
  • Amcor Dehumidifiers
Most Popular Question
dehumidifier not
  • Dehumidifiers
