20 Most Recent Polaroid PDM-1058 Portable DVD Player Questions & Answers
0answers
2answers
I have a Polaroid PDM-1058 DVD player that keeps
If the unit was used a lot there may be the possibility that the laser assembly is going bad...these are not too expensive and are relatively easily replaced..you will have to open the unit up to look at the laser assembly...there should be a sticker with a part number on it...find this number then go to mcmelectronics.com to see if you can obtain one and replace it...the laser rides on rails and is easily removed by taking 1 rail off and then the laser itself...if you do decide to change the laser..make sure you un-bridge the solder short on the new laser...this is done to prevent static from damaging the laser...it will either be on the ribbon cable or on the board on the laser...simply plug it in and remove the solder short...then try unit to see that it works
1/14/2011 10:14:54 PM • Polaroid... • Answered on Jan 14, 2011
BAD DISC PROBLEM ON PDM1058 POLAROID
you can try to clean the laser under the disc door
1/14/2011 4:06:38 PM • Polaroid... • Answered on Jan 14, 2011
It has power but will
Did you try a lens cleaner? If the lens is dirty/damaged then the DVD will not play. Use a branded lens cleaner(Sony is recommended). Just pop it into the drive and play it. It runs like a normal DVD except that the brushes will pop out of the cleaner disc and wipe the lens. You can get one on ebay for about 10-15 bucks.
6/6/2010 4:34:06 PM • Polaroid... • Answered on Jun 06, 2010
I am in the wrong region at the moment i n Uk
what are you willing to pay me for this information
12/31/2009 8:24:21 AM • Polaroid... • Answered on Dec 31, 2009
My Polaroid PDM-1058 Portable DVD Player has a
it sounds like the input for the power on you dvd player died and that is alot more than 1 or 2 things to solder
8/19/2009 12:52:27 AM • Polaroid... • Answered on Aug 19, 2009
Polaroid portable dvd-my screen says 'this screen
One of the button of your polaroid dvd player is still in active mode.Try to keeps pressing all the button, so that it will go back to inactive mode.
7/23/2009 10:54:54 PM • Polaroid... • Answered on Jul 23, 2009
2answers
Lost power cord for Polaroid PDM-1058 portable DVD player
I've looked for the same thing and the only place I can find it is eBay for about $25
5/31/2009 7:54:42 PM • Polaroid... • Answered on May 31, 2009
3answers
POLAROID PORTABLE DVD PLAYER CHARGES ON WALL ADAPTOR BUT NOT ON CAR CHARGER
You can buy it at followig link:
http://recoupit.com/Portable-DVD-Players/c177182/
http://cgi.ebay.com/Polaroid-MPA-6930A-AC-Power-Adapter-9-5V-3-33A_W0QQitemZ140312970734QQcmdZViewItemQQptZDVD_Players_Recorders?hash=item20ab4e05ee&_trksid=p4634.c0.m14&_trkparms=|301%3A0|293%3A1|294%3A30
5/28/2009 7:27:18 PM • Polaroid... • Answered on May 28, 2009
Does show anything on the screen
If nothing shows on the screen, U may have a bad screen or video card in the machine. There really is no solution except to get it repaired if it is in warranty or taking it to a shop for repair, or buying a new unit
5/9/2009 1:12:11 AM • Polaroid... • Answered on May 09, 2009
My portable dvd player is
It sounds like U have a bad lens. Try a lens cleaner. If it is the lens, it wont read anymore discs. Sometimes it will also make a clicking sound and show disc error/no disc cryptic messages on the screen.
5/9/2009 1:10:01 AM • Polaroid... • Answered on May 09, 2009
"no disc" error message
Did this problem just start? It may be due to the lens no longer reading the disc. Try a lens cleaner. If your lens went south, it usually is paired with a clicking noise or/and the combination of a no disc/disc error message. I would also recommend staying away from Polaroid dvd players and tv's in the future. They have a habit of not making parts available, especially after the warranty.
5/9/2009 1:08:02 AM • Polaroid... • Answered on May 09, 2009
2answers
Battery won't charge
try freezing it it may take some time but mine i just put in the freezer every night before i sleep and it is slowly geting better
5/9/2009 1:04:34 AM • Polaroid... • Answered on May 09, 2009
3answers
Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
3/29/2008 10:55:49 PM • Polaroid... • Answered on Mar 29, 2008
Polaroid PDM-1058 Portable DVD Player Logo
27 questions posted
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
polaroid portable dvd player charges
  • Televison & Video
