20 Most Recent Polaroid FLM-323B Television Questions & Answers
Hi.
If your happy to remove the back casing of the the TV set.
Lay set face down on table with several towells laid out flat under it.
Undo all screws holding back on & lift it off you may need to remove tv stand to remove back.
Once back is off either locate speakers & unplug the leads from them remember to insulate the loose wires & tie them up out of the way.
Or trace wires from speakers to there plugs & sockets on main Pcb & unplug them & thats it.
Screw rear of set back on & ensure volume is set low or at zero.
http://dysonmanuals.llc.nu/
Polaroid... | Answered on Jan 10, 2018
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.//
Polaroid... | Answered on Dec 16, 2017
INDOOR ARIEL MAY BE TO WEAK LO FOR TV APLIFIER ARIEL ON EBAY OR GET OUTSIDE ONE FITTED
Polaroid... | Answered on Sep 28, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Polaroid... | Answered on Apr 12, 2017
You should be able to get to the menu with the front panel buttons. Otherwise, try unpluging for a minute, this may allow a reset. Please do not rate me if this is no help.
Polaroid... | Answered on Jan 26, 2017
The tv Tuner signal board is the causes and the problems.That the board,where the antenna signal wire plug into it to receive the incomming broadcasting tv signal channels stations.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Polaroid... | Answered on Aug 24, 2016
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Polaroid... | Answered on Dec 21, 2015
It called pixel retention, in most the case, it is a temporary problem, sometimes it will go away itself, but if you physically put pressure to the LCD panel, it may damage the crystal container cone, the damage will be permanent.
Polaroid... | Answered on May 21, 2015
Hello Gary, you can find the fuses on the power supply board which is located inside the TV, they look like medicine capsules made from glass and for contact capped with a sheet of metal. Here is a picture of a SAMPLE LCD power supply board. cyberdyers.jpg
Polaroid... | Answered on Feb 24, 2015
Look at the top of the main board. There are two capacitors together. Look at the area just to the top of the board and behind the capacitors. There is a very small resistor(flat) soldered to the board. I had the same problem, so I removed bad resistor and replaced it with a 10 ohm resistor from Radio Shack. Sound is back. Cost a couple of bucks and took about an hour in all. Hope this helps.
Polaroid... | Answered on Dec 30, 2014
Do a hard reset to this set, and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If it do not help you; check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Polaroid... | Answered on Dec 04, 2014
FLM-323B same problem, black screen. Checked out the power board and there is no 24v on it. Took the board out, let it cool off, put it back in. Got my TV back for a while, checked for 24v and it is there. Worked for a few weeks, now it's out again. Known issue with Polaroid, and if it's out of warranty, might as well throw it away because they WILL NOT help you. Personally this was my first and LAST POLAROID TV ever, TOTAL JUNK.
Polaroid... | Answered on Jul 28, 2014
backligth has no power check the inverter board for any open fusable resistor or open fuse and cold solder
Polaroid... | Answered on Feb 13, 2014
Polaroid FLM-323B Television Logo
303 questions posted
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Polaroid Televison & Video
Most Popular Question
screen rubbed leaving black smudges
  • Televison & Video
