20 Most Recent
Fujitsu fi-5110C ScanMaker Scanner Questions & Answers
I was just upgraded to
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/
kindly update the fujitsu scanner driver for your 5110 scanner to windows 7..
I have a Fujitsu fi-5110C
Hello, Jim.
The most common cause is from a particle
of ink or
dust that is attached to the lamp or the glass covering the lamp. As the page
runs over the lamp, it registers that spot as black and causes a line to run the
length of the page.
To fix this, simply remove the particle from the glass or
lamp. The location of the particle will correspond to the location of the line
on the page. So note which side of the page this occurs.
Here's an article from eHow regarding cleaning the scanner glass: http://www.ehow.com/how_14267_clean-scanner.html
Pay attention to that black particle.
Hope this helps.
The fujitsu fi-5110C won't scan all pages just
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Reinstall the scanner
The printer my have corrupt the setup of your scanner. So try and uninstall the setup properly and install it again.
How to unistall go to your control panel-Double click on Add or remove programs-then click on the scanner's setup then click on remove or change.
LATEEF FOR FIXYA
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Can't install scanner
First chek if the USB ports are working by inserting a known working device, like a pendrive. If it is working then change the USB cable. Buy a good quality cable designed for USB 2.0. This is shielded cable and this should solve your problem. Pls ensure that scanner is powered.
S. Mohan, Chennai, India
