20 Most Recent Fujitsu fi-5120C Questions & Answers
Hello, I work for a doctor's
it is logical that in an office where document scanning is important and vital, you would call in the service technicians to fix it so that the interruption is minimal
11/28/2017 1:08:57 AM • Fujitsu fi-5120C • Answered on Nov 28, 2017
0answers
Calibrate
on your scanner program in your computer there should be calibration setting that will reset your scanner properly
4/20/2017 9:23:16 AM • Fujitsu fi-5120C • Answered on Apr 20, 2017
0answers
Keep scandall in background
Possibly you need a more professional program. Scanning utilities following scanners (free) aren't a "Production" tool. Using PixEdit you can scan with one single click and after the scan is finished you could scan the next stack of pages. While it is then scanning the previosus document is processed with blank page removal, deskew, OCR, barcode recognition and a lot of other stuff. The reason is PixEdit using the mulitple cores in modern PCs.
12/5/2015 7:55:03 AM • Fujitsu fi-5120C • Answered on Dec 05, 2015
2answers
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
12/5/2015 7:54:53 AM • Fujitsu fi-5120C • Answered on Dec 05, 2015
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel. http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
10/14/2015 2:48:53 PM • Fujitsu fi-5120C • Answered on Oct 14, 2015
After installing the scanner I get a message that
first most computers are plug and play, if yours is not then you need to load the software that came with the scanner, only then will the computer see the scanner
4/9/2015 10:37:32 PM • Fujitsu fi-5120C • Answered on Apr 09, 2015
Scanner continues to search for a page after all pages have been scanned.
Usually the "paper empty" sensor flag gets stuck and does not return or "fall" to the empty position when the paper ends. The flag is right next to the pad assembly. Use a compressed air can to remove any dust-debris from the flag housing. Because this flag uses gravity to return to empty position it might be usefull to use a spring to force it. Let me know if you need further assistance.
2/15/2015 8:18:55 PM • Fujitsu fi-5120C • Answered on Feb 15, 2015
I opened the fujitsu software operation panel and
Sounds like driver related problem to me. Download this: Driver Update Software and follow the instructions to update. Best of luck Simon
1/7/2015 2:21:18 AM • Fujitsu fi-5120C • Answered on Jan 07, 2015
Black vertical line on scan
Usally this is due to dirt accumulated on the glass surfaces of the scanner. Make sure that both glass windows inside the scanner are clean. Next step is to clear both CCD's (read heads) but in this case you need to disassemble the scanner.
10/18/2014 8:16:20 PM • Fujitsu fi-5120C • Answered on Oct 18, 2014
Why is the scan skipping part of the page?
Either you are putting the page in a wrong manner. Or you have to fix in your settings, before you start scanning on your computer. I am regarding to the scanning setting which are available on your computer. If its set to DINA4 (provided you want to scan a DIN A4 page) and you have put the page in the correct manner, then it should scan perfectly. Otherwise, the device might be defective. In that case you should consider contacting Customer Support.
10/2/2014 6:23:16 PM • Fujitsu fi-5120C • Answered on Oct 02, 2014
Fujitsu fi-5120C Logo
158 questions posted
Top Fujitsu Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
fi Fujitsu
  • fi Fujitsu
Most Popular Question
opened fujitsu software operation panel
  • Office Equipment & Supplies
