20 Most Recent Canon EF 70-300mm f/4-5.6 IS USM Lens Questions & Answers
2answers
Autofocus problem with 70-300mm is usm
Probably needs a new ribbon cable in the lens. This flexible cable maintains the contact as the lens is zoomed in and out. If it is still under warranty take it back to B&H for a simple repair.
10/2/2022 5:19:06 PM • Canon EF... • Answered on Oct 02, 2022
1 Solution for
It may be damaged from the drop so take it for a repair to you nearest camera repairer. Check out the cost before as it may not be worth repairing and a replacement would be in order
9/24/2019 7:59:52 PM • Canon EF... • Answered on Sep 24, 2019
Replace the broken ribbon cable in the lens
9/2/2016 10:36:57 PM • Canon EF... • Answered on Sep 02, 2016
0answers
Sigma 70 300
Be the first to answer 5/3/2014 3:59:08 AM • Canon EF... • Posted on May 03, 2014Be the first to answer
0answers
Hi I have a Canon
Be the first to answer 1/1/2011 12:49:04 AM • Canon EF... • Posted on Jan 01, 2011Be the first to answer
0answers
WILL THE ABOVE LENSE WORK WITH A CANNON DIGITAL
Yes, it's suitable for 35mm EOS mount Canons and all digital models. If the digital SLR has an APS-C sensor then the image will be cropped and will give the same viewing angles as a 112-480mm on a 35mm camera.
10/3/2010 4:48:13 PM • Canon EF... • Answered on Oct 03, 2010
Canon 12x36 is ii stabilization is not working properly. Stabilization tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
3/21/2024 12:18:08 AM • Canon Cameras • Answered on Mar 21, 2024
Canon Prima BF-800 Zoom Compact Point and Shoot Zoom Camera. I can't use the date feature?
The date feature has to be set up and there is always a way to turn it off and on. I was looking for a manual, but this is not a North America model. This link might work better for you.https://www.google.com/search?q=canon+prima+bf-800+zoom+manualThe Error Codehttps://www.google.com/search?q=canon+prima+bf-800+zoom+hr+ha+errorMake sure the batteries are good!..
2/18/2024 8:48:21 AM • Canon Cameras • Answered on Feb 18, 2024
I have problem with my canon a95 a Change battery but still my camera say me to change a battery
If you are using Nickel Metal Hydride rechargeable batteries, they have come to the end of their lifespan. Buy New or use AA Lithium batteries. https://www.google.com/search?q=canon+a95+battery ..
2/15/2024 10:55:54 PM • Canon Cameras • Answered on Feb 15, 2024
My Canon AV1 only shoots in B mode, the light meter works correctly, and everything else seems fine. Has anyone had the same issue and found a solution?
If your Canon AV-1 is only shooting in Bulb (B) mode, it could be due to a malfunctioning shutter or aperture control. However, since the light meter is working correctly, it is possible that the issue is with the camera's shutter speed dial. The shutter speed dial is located on the top of the camera and should be set to a specific speed when shooting in aperture-priority mode. If the dial is stuck in the Bulb (B) position, then the camera will only shoot in bulb mode. I would recommend taking your camera to a professional camera repair shop to have it inspected and repaired if necessary.
1/21/2024 11:01:27 PM • Canon Cameras • Answered on Jan 21, 2024
Any instructions about repairing Canon Legria HF200?
Real help that is not AI Generated! Articles and instructional videos https://www.google.com/search?q=canon+legria+hf200+clean+lens+and+sensors ..
12/30/2023 9:14:41 PM • Canon Cameras • Answered on Dec 30, 2023
2answers
Canon PowerShot G5 Camera. Can the LCD screen on the Canon G5 be repaired of replaced?
Yes of course. Take it to your local Canon Service Centre. https://www.google.com/search?q=Canon+Camera+Service+Centre ..
12/14/2023 11:09:56 PM • Canon Cameras • Answered on Dec 14, 2023
Best canon ef lens for a canon rp with ef-rf adapter.
Ef85 f 1.8 ISNT to bad fun cheap lens can be a 50mm f 1.8
12/10/2023 9:59:05 AM • Canon Cameras • Answered on Dec 10, 2023
Why wont my 2gb sd card work with my Canon zr200
card max is 8 mb https://www.manualslib.com/manual/24534/Canon-Zr200.html?page=90#manual
10/20/2023 4:59:29 PM • Canon Cameras • Answered on Oct 20, 2023
Hi, My Canon Powershot A480 camera keeps on scrolling by itself
i kindly advice you restart the camera ,it may fix the problem,.Also ensure on the camera's buttons or around the scroll wheel there is no dust .If it persist try to reset factory the camera
9/21/2023 2:54:45 PM • Canon Cameras • Answered on Sep 21, 2023
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'. I think the other answer is an AI Answer Bot.
9/13/2023 6:47:07 PM • Canon Cameras • Answered on Sep 13, 2023
Canon EF 70-300mm f/4-5.6 IS USM Lens Logo
Popular Tags
11 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
autofocus problem 70 300mm usm
  • Cameras
