20 Most Recent
Sanyo PLC XU48 Multimedia Projector Questions & Answers
Why does picture look slooped at top and rest of
Thats call keystone. That happen when projector is not properly align with screen. Most of projectors come with digital keystone corrector in the menu settings. Ensure is setup to 0 and check lens of the projector is at the center of the screen. Also if the projector is too high or too low will cause that problem too. Just move it arround until you find the right place to mount it. Best of luck
Thought the bulb was bad, replaced and still no light.
where did you get the lamp from? if you got it from a reputable dealer, then i'd say the ballast is bad and needs replacing. if you got it from "bob's bulbs", then it may be the lamp. but the only way to test it is to put it in a known good projector.
Lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
