20 Most Recent
JVC DR-MV1S DVD Recorder/VCR Questions & Answers
JVC DR-MV1S VHS Tracking
No manual tracking or if there is it wont help.either heads are worn or possibly dirty.if u open it .i assume u have.the silver drum has little notches around it.2 ,4,or 6 these are the heads.get some alchol or aftershave will do.take a peice of card playing card size is ok .must be plain not printed.apply some aftershave alchol to card not dripping ,hold card against the dum then with other hand turn the drum back and forwad not moving the card,u may damage heads.when u check card it should show some dirt reassemble and try.otherwise its museum time show the grandkids see if they know what a tape is
Machine blinks "loading"
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Disk error
It could be the lens on the laser. There are special cleaning disks for that.
MY JVC DR-MV1S DVD VIDEO
Your JVC DR-MV1S DVD VIDEO RECORDER & VIDEO CASSETTE RECORDER is having a defective board that is why it is misbehaving.
The Board controls the whole affairs of the unit.
Irregular power supply, excess power, or power surge may have affected the board of the JVC DR-MV1S DVD VIDEO RECORDER & VIDEO CASSETTE RECORDER.
The board is just like the CPU, this what controls the unit.
The board needs to be replaced for the JVC DR-MV1S DVD VIDEO RECORDER & VIDEO CASSETTE RECORDER to function well again.
Fixing this problem is not a DIY. I think you might be needing the help of a repairman.
Sorry if it sounds disappointing, but it is a truth that must be told.
Good luck.
JVC DR-MV1S won't turn on.
the problem is power failure in the untit's system like faulty capacitators....which when they fail will not allow the correct amount of electricity into it's main operating "motherboard" of the dvd and or vcr....if not...try to hold down the power button next time it goes off...for a while and see if it turns off again...and see what happens.
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
