20 Most Recent Hotpoint WMA46 Front Load Washer Questions & Answers
Does not empty at end of wash cycle (not blocked or pump)
faulty program board not progressing call a technician
1/1/2018 3:08:59 AM • Hotpoint WMA46... • Answered on Jan 01, 2018
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
4/4/2016 9:05:20 AM • Hotpoint WMA46... • Answered on Apr 04, 2016
Hi door latch as broken off, does anyone know the correct part number? cheers steve
If you look up Hotpoint-Spares.co.uk and select your machine model and you can purchase it on line or ring them up on 01489 782492 they are very helpful. Hotpoint Spares co uk For all your hotpoint spares and accessories
5/29/2014 10:58:39 PM • Hotpoint WMA46... • Answered on May 29, 2014
0answers
Wash programmes not changing
Unless meets water from tank necessary to check the pumps a discharge and clean him from rubbish.
11/12/2013 8:13:20 PM • Hotpoint WMA46... • Answered on Nov 12, 2013
My circuit board got damaged as a result of a
You may not be able to have it repaired, depending on the damage. It's hard to find a place that still rebuilds those boards.Could you give me the full model number, and I'll see if I can find you one?
10/23/2013 12:13:14 PM • Hotpoint WMA46... • Answered on Oct 23, 2013
I have just been given this machine by a friend.
Do try another program before you give in to the machine. Kolbrun
9/18/2013 8:41:42 PM • Hotpoint WMA46... • Answered on Sep 18, 2013
2answers
Hotpoint wma46, my machine does't seem to be
Hotpoint wma46 This video will show you how to keep your soap draw clear and how to service the parts Please remember to subscribe to our YouTube channel for all appliance tutorials a 4 THUMBS rating is appreciated for answering your FREE question
7/30/2013 1:23:06 PM • Hotpoint WMA46... • Answered on Jul 30, 2013
0answers
Wma46 flashing lights
What are the lights that are flashing?
3/17/2013 7:50:04 PM • Hotpoint WMA46... • Answered on Mar 17, 2013
How do i remove the top cover
Remove two screws from rear of machine and slide forwards
1/7/2012 2:31:55 PM • Hotpoint WMA46... • Answered on Jan 07, 2012
How do I refit the belt on my hotpoint aquarius
(providing yours is front loading?)
The quick answer is 'DON'T'! Purchase a replacement and fit that 'cos the old one will only come off again!
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT AGAINST THE MOTOR OR FRAME; THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
10/20/2011 7:50:52 AM • Hotpoint WMA46... • Answered on Oct 20, 2011
Due to a leak i have no hot water supply to the
Yes provided that the wash required is not for full sterile condition you can have the cold wash using a good detergent.
Choose the appropriate program that does not have the HOT wash and it will progress the cycle.
8/19/2011 9:33:03 AM • Hotpoint WMA46... • Answered on Aug 19, 2011
My clothes do not seem
Mine does this too. I've also noticed that no water is visable through the door window and I'm sure the bottom of the drum should be submerged. I've been adding a bowl of water after the m/c has taken water in, which seems to help, but I don't know what the long term solution is. But definitely get a cloth out and clean the soap unit and housing!
8/1/2011 1:01:24 PM • Hotpoint WMA46... • Answered on Aug 01, 2011
Hotpoint WMA46 Front Load Washer Logo
91 questions posted
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
wash programmes not changing
  • Washing Machines
