20 Most Recent
Gateway FPD 1730 17 in. Flat Panel LCD Monitor Questions & Answers
My Gateway FPD 1730 Monitor
all PCs new out of the box,. go to sleep
by law here (usa energy star laws)
2004 monitor
99% are all dead now, due top CCFL back lamp tubes dead
they all do that now. even intermittant for the same reasons
EOL on CCFL, end of life , all.
used 10 hours a day for 5 years and bingo EOL , happens, all.
How do I Adjust contrast
To adjust contrast and sharpness 1. Press osd button (on screen display)
2.Use the up and down arrows to highlight selection then press auto/set button
3. Use the arrow keys to adjust settings
4. When you have finished press the osd button to save and exit
Thank you for using fixya.
Picure does not fill out the screen
First try it on another video source. If it changes it's the source. If I hook a monitor to my laptop and put it display and external at the same time it uses the wide screen settings of my laptop display.If I go external only it fills it totally out. Also get into the on screen display and find where you can do reset or auto adjust. If nothing works regardless of machine it's on then the display may be failing and need service. Capacitors on the power board in LCD monitors since about 2004 have been prone to failure.
The welcome ad and tour button is on my desktop
Have you tired simply restarting the computer? You can also right click the Task Bar and choose Task Manager. Look in the applications Tab and stop it from running there. If it is not listed in Applications then look in Processes and stop it there. The Tour will stop running after you stop it 3 times.
How to resize the desktop?
I assume you're running Windows XP? Control Panel --> Display, Settings tab. Change the resolution using the slider. Choose different ones until you find one that works.
Hope this was helpful. If so, please leave a rating!
Gateway (FPD1830) LCD Monitor
It can be bad caps in the power supply, bad inverter circuits (check the green color fuse (F1, 4A 125V) close to the heatsink and a trim pot), bad inverter transformers, bad lamps.
You open it up using flat blade screw driver starting along the bottom edge of the case. Post back what you see insdie so we can guide you further.
My fpd 1730 moniters brightness and contrast are
nonnie707, It is very possible that your monitor's internal or external (lay on floor) "switch-mode-power-supply" has a problem. Prove that your pc is working by connecting KNOWN GOOD monitor to your pc!!! If you are not electronics technician then you will need to question Gateway as to warranty service or possible swapout for a REFURBISHED unit if your unit is deemed as premature failure. May cost $ for swap. READ my FIXYA profile and that of other FIXYA TECH's (buddymc, budmrtn) for more options as to "what to do"!!! Remember, If very strange and weird things start to happen (occur) with "cold-cathode-fluorescent-lamp" backlit LCD display, the first place I would investigate would be the units "switch-mode-power-supply" Good luck with the repair. 12fixlouie
When system restarts, monitor blank
If you can see a dim image on the monitor then there is a
back-light problem.
The fault could be an inverter problem which supplies high voltage to the CCFL lamp or the CCFL lamp maybe faulty. The CCFL lamp is a mini fluro tube.
Check out LCD parts for service, parts and DIY info - click on this link :-
www.lcdparts.net
Unhooked and moved my computer to another part of
Sounds as if your monitor is not receiving a signal from your video card. In all likelihood, the video card came unseated during the move. Open the case and re-seat the video card, that should do the trick.
Write back if that does not solve the problem.
-Jon
