20 Most Recent Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Questions & Answers
Failing to configure router
try a blank password could be 192.168.2.1
2/10/2018 11:23:26 PM • Gateway Belkin... • Answered on Feb 10, 2018
Setting up Linksys Wireless Router for Satellite
In Windows, run "cmd". Type "ping google.com". If you can ping google.com, the problem is with the websites you are trying to surf. If you cannot ping google, there is a problem with your connection. This sounds like a used wireless router You might need to configure it. See this: https://www.linksys.com/us/support-article?articleNum=139668#H2
10/16/2017 6:41:16 AM • Gateway Belkin... • Answered on Oct 16, 2017
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
6/1/2017 8:40:48 AM • Gateway Belkin... • Answered on Jun 01, 2017
How do i secure my belkin 54g router?
Go to the setup page for the router (IP 192.168.1.1) and set up the WPA-PSK [TKIP] security. It will allow fairly simple setup, and only provide the pass code to house members.
6/1/2017 6:52:57 AM • Gateway Belkin... • Answered on Jun 01, 2017
0answers
Looking to set up security for belkin 54g wirelrss
Hello Ames3pack Just with your windows firewall, or antivirus program, can do the trick. but if you have the router manual better, ! then you can go inside the box with the IP and set up things! Carl
1/30/2017 8:56:55 PM • Gateway Belkin... • Answered on Jan 30, 2017
How to lock my belkin 54g router
11/2/2015 8:31:21 AM • Gateway Belkin... • Answered on Nov 02, 2015
Computer says ivalid ip
11/2/2015 8:29:01 AM • Gateway Belkin... • Answered on Nov 02, 2015
How to cinfigure a Thomson tg585v7 router
11/2/2015 7:56:15 AM • Gateway Belkin... • Answered on Nov 02, 2015
3answers
I have a Belkin router
You don't need the setup disk check out my four tips here for Wireless Printer and Wireless Routers.
http://www.fixya.com/support/r3559234-set_up_a_wireless_printer_on_your_router
http://www.fixya.com/support/r3958382-access_router_or_cable_modem_admin
http://www.fixya.com/support/r3943298-find_wpa_psk_or_wep_key_in_hex_ascii
http://www.fixya.com/support/r3902413-protect_adsl_bandwidth_download_speeds
The setup disc that you maybe able to find is just a wizard and can't setup printers to your router like in my first tip.
9/16/2015 4:09:32 PM • Gateway Belkin... • Answered on Sep 16, 2015
Can not log on to belkin 54g set up page
Few things you can try. First would be to do a factory reset. Do this by pressing the reset button for at least ten seconds. If that doesn't work you could try switching ethernet ports. If that doesn't work your router is probably dead.
8/3/2015 7:44:48 PM • Gateway Belkin... • Answered on Aug 03, 2015
How do i connect my laptop to my wireless network?
On most machines you should simply have to click on the wireless icon, which is usually in the bottom left corner. After that you click on the network that you want to join and may have to input password.
8/3/2015 7:35:56 PM • Gateway Belkin... • Answered on Aug 03, 2015
What happens after a router is rebooted
No problem unless it has a password to enter (192.168.x.x) in the router configuration.
1/14/2015 3:22:39 PM • Gateway Belkin... • Answered on Jan 14, 2015
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
rate me solved if its helps
5/21/2014 5:26:12 AM • Gateway Belkin... • Answered on May 21, 2014
Can't set up Belkin 54g Router with MTNL broadband
Samay, You should reset your router to clear all information from it. The best procedure to fully clear your device would be to press the reset button with power on for 30 seconds; while continuing to press the reset button, remove power from the unit; and while continuing to press the reset button restore power for 30 seconds. You should now be able to access the menus after the unit boots up with the default user name/password for the unit. If you do not know them, just Google [your router name] default user name and password. You can now set up the router to meet your requirements. There is a lot of information that will help you on the Internet, but having a clean booted router is important to start with.
3/18/2014 2:35:49 PM • Gateway Belkin... • Answered on Mar 18, 2014
Upgraded to windows 7 and i am unable to connect
I'm thinking modem/router combination. first power down modem and router. Then leaving router unplugged, power up modem, make sure it's sync up then power up router. If this is a wireless connection search for your networks name on computer/laptop..ie View wireless connection. Windows allows a automatic setup if the wireless connection is unsecured. If it is secured Windows 7 will prompt a pass phrase/ or access code. Good luck. Repeat process if necessary
12/22/2013 9:48:48 PM • Gateway Belkin... • Answered on Dec 22, 2013
3answers
Trouble connecting new laptop to the internet
when you put the mouse over the network icon in your taskbar, it will say access: Local & Internet or local only.
if Local & internet you have a connection to the internet, if local only then open internet explorer, tools, internet options, connections and check that there is no default connection, it should be never dial a conection thats ticked or greyed out.
12/4/2013 4:59:06 PM • Gateway Belkin... • Answered on Dec 04, 2013
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
352 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
belkin 54g
  • Computers & Internet
