20 Most Recent HP Compaq Business nc8230 Notebook Questions & Answers
Hp slow when installed windows 7
HP does not post drivers for win 7, so this means it didn't come with win 7 and they don't want people loading win 7 on it.You probably don't know the hardware on it well enough to get the right drivers.
4/8/2013 7:11:16 PM • HP Compaq... • Answered on Apr 08, 2013
2answers
When the laptop is turned on, HP and Intel are
Windows is not booting for some reason, verify no devices are connected, no discs in tray, remove battery and power, then reposition battery and power and try again. If no go you can try re-seating the memory, disconnect power sources and touch a metal surface to discharge static. You will see panels at the bottom of the unit. The one for the memory is usually the one in the center of the whole unit. This video will show you to remove and reposition memory.
Try pressing F8 repeatedly for advanced boot options. Then safe mode or repair your computer, and then system restore. For full recovery with data loss press F11
3/31/2011 4:46:57 PM • HP Compaq... • Answered on Mar 31, 2011
Where , what size
Hi
Do you have the manual to go with the laptop if not if you go to
http://welcome.hp.com/country/uk go to support and or drivers
type in the make model and operating system then search for manuals and download it
save it to a pendrive or your desktop and you will need adobe reader installed to be able to read it
this should show you how to replace the cmos battery and where to find it
have fun
1/14/2011 2:05:39 AM • HP Compaq... • Answered on Jan 14, 2011
HP Compaq Business nc8230 PC Notebook
WHATS YOUR PROBLEM
[email protected]
12/10/2010 6:34:54 PM • HP Compaq... • Answered on Dec 10, 2010
Hello! I have a problem
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Invertor board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both. But most likely it is the CCFL (Lamp). Its life is limited and depending upon how long it has been in use, you can have a better idea - if its the CCFL or Inverter.
Rest assure that your system is ok and you can check it by connecting you laptop with some external display, which would work fine.
So, my advice is that you get it properly checked by any professional for replacement of CCFL.
Hope this answers your question!
CreativeTECH
11/25/2010 11:03:58 AM • HP Compaq... • Answered on Nov 25, 2010
I have a HP 8230
You should be able to plug in the AC adapter without the battery & get it to work.
10/15/2010 4:19:28 AM • HP Compaq... • Answered on Oct 15, 2010
Forgot password for compaq nc 8230 turn on power
How doI know this is your machine?
6/29/2010 9:57:19 PM • HP Compaq... • Answered on Jun 29, 2010
2answers
HP nc8230 no BIOS setup and system time error
the simple thing is that are the both system compartible?so if they are not just compartible go to the local pc outlet in your area and get a compartible one better you go with the faulty screen so it could be easily verify.
6/27/2010 4:16:22 PM • HP Compaq... • Answered on Jun 27, 2010
How to upgrade bios of nc8230? I need steps
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=447338&prodNameId=447352&swEnvOID=2094&swLang=8&mode=2&taskId=135&swItem=ob-74577-1
It looks, from a cursory reading of the install instructions, that you will be able to flash the BIOS from within Windows.
3/9/2010 6:14:14 PM • HP Compaq... • Answered on Mar 09, 2010
2answers
I can not get the laptop to boot up. It will not
Try and replace the cmos battery. Good Luck.
11/20/2009 7:41:00 AM • HP Compaq... • Answered on Nov 20, 2009
Broken power plug in pin on computer
Ebay has a very good selection. Just put your make and model in the search box and away you go.
9/17/2009 12:50:50 AM • HP Compaq... • Answered on Sep 17, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered on Apr 17, 2024
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
HP Compaq Business nc8230 Notebook Logo
Popular Tags
17 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp slow when installed windows 7
  • Computers & Internet
