20 Most Recent
Averatec 3120V Notebook Questions & Answers
Forgot password to logon
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
good luck
I need a new fan for an Averatec 3120
I found two on a google shopping search, couldn't find on ebay.
Not the cheapest fans on the market.
http://www.google.com/products?q=averatech+3120+fan&aq=f
RAM for AVERATEC 3120V
Max for this form factor is 512mb. It can be upgraded. Here is step by step instructions
http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Notebook/Max..ing_Out_Memory_on_the_Averatec_3120V_Slim_Notebook
you can buy the ram here for about 18 bucks with a credit card and free account setup
http://cgi.ebay.com/Viking-512Mb-PC13364X64CL3-512MB-PC133-SDRAM_W0QQitemZ120445441132QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b1b946c&_trksid=p3286.c0.m14
Good Luck! Your Amigo!
Ruben
Averatec 3120 hard drive choices
So, you google it.. it tells you what it is, in this case a XXX size 30GB drive, how fast etc.. then you go see how fast a HD your laptop can use ATA66. ATA 100 etc..
then you go on ebay and see what is available..
Perhaps you try google groups to see if there are any complaints on the model you are thinking about.
Then you bug your local PC shops for something the same physical size, or smaller , for a a price close to what you see online..
If you do it yourself, you'll need tiny screwdrivers and patience.
A laptop to desktop ide adapter ($10 on ebay) will help a lot too..
Good luck..
Averatec 6200 motherbord specifications ? Compatible procesor upgrade with SSE 2 thanks
The Averatec 6200 laptop was released in 2004 and is powered by an AMD Athlon XP-M 2400+ processor with a clock speed of 1.8 GHz . The motherboard of the Averatec 6200 is based on the SiS741 chipset. The laptop comes with 512 MB of RAM and a 60 GB hard drive . The laptop's display is a 15.4 inch, 1280 x 800 (WXGA) screen.
As for the processor upgrade, the Averatec 6200 is compatible with processors that support SSE2 2. SSE2 is an extension of the IA-32 architecture, based on the x86 instruction set. Therefore, only x86 processors can include SSE2. The AMD64 architecture supports the IA-32 as a compatibility mode and includes the SSE2 in its specification. This means virtually every modern Intel and AMD CPU supports SSE.
11/19/2023 8:49:05 PM •
Averatec...
Answered
on Nov 19, 2023
Averatec e1200 laptop i think it caught a virus
Hold the delete button when you turn it on and see if it loads BIOS up. If the screen displays the BIOS OK then you can change the boot sequence to CD/DVD or USB first and do a fresh windows installation. You could also try holding F8 at bootup and try loading safe mode. If this doesn't help it could be a problem with your screen or the wiring going to the screen. Possibly also a problem with the graphics card.
11/23/2017 6:51:48 AM •
Averatec...
Answered
on Nov 23, 2017
