20 Most Recent
Averatec 6100 Notebook Questions & Answers
Heats up too fast. Is
mine was doing that . got a can of air and blew out the fan and heat sink area. helped alot
I cannot access any programs
The one asking you to buy the software itself is a Malware. I suggest you to Install Malware Bytes (Freeware) easily availble in the net and run it.
That should take care of it.
Good Luck.
I have a avetec 6100 laptop. How do I get it to
Usually there is a slide switch or a key combination (Fn+F2 or Fn+F7) in order to enable your wi-fi reception. After a while you will be prompted to choose from an existing wireless network.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Keyboard malfuction like if u press letter "o" it
I believe the Num Lock is turned on on your laptop. Try looking on the keyboard which key you have to press altogether with the "Fn" key to turn Num Lock off. Or, alternately, check in user's manual how to switch this feature off.
System restore did not work
Buy a normal Windows CD and Install windows
Then use UNIBLUE driver scanner to scan for your drivers
And it will have better outcome then just restoring
Keeps going to blue screen
you have to repair your operating system, so it will overwrite corrupted files but make sure you dont format your ddrive, you might lose your files.
