20 Most Recent
Canon PC-D340 All-In-One Laser Printer Questions & Answers
Canon D340 Copier System Error E000
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
Canon PC D340. The display
Because the paper size of your software like Word is "custom", and the paper size setting of the printer is "ltr", the printer won't print until you change the paper size to "freesize". Change it in "Additional Functions" menu on the printer (Canon D340). (Word will change the paper size setting automatically if you adjust the margins of your paper too far)
Canonpc d340system error100
the machince is giving an error of e100, i have tried to change the drun together with rear unit but still gives the same error
System error e100
Hi,the most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to operate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
"BD interval error"..
just enter service mode & reset ( CLEAR ALL )
Additional Function>>>28>>>>Additional Functions
Scroll through to find CLEAR Select all...
Rate me if it was helpfull....
If envelope printing Canon PC-D340
You need to make sure the paper size and that of the printer matches in the dialogue box.i.e assuming you a printing an envelop DL size, make sure your envelop is the exact size you choose in your page layout.secondly, open the properties in the printer dialogue box, where you have letter, change the default "letter" paper to you envelop size.Note: if your envelop size is not accurate and the actually printed, you will still receive "incorrect paper size" error. At this point I turn of mine and turn on again.
