20 Most Recent
Labtec Pulse 285 Computer Speakers Questions & Answers
Speakers won't power on when plugged in
firstly check your power cable by moving the wire in various directions while it is plugged in ac outlet and powered on, if it lit up the standby power LED then the prob lies on the power cable. If not, try opening the speaker system box itself (be sure to unplugged the power cable before opening the box), then visually check inside for the little cylindrical glass type tube(if the circuitry still uses this kind of fuse) if it is burnt-out.Hope this help pal...
I don't have $12, I
if you are having problems
with your sound
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question mark? Right click to reinstall
drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar
if his does not fix the
problem
have you tried this control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer
hope this helps
No sound coming from speakers
drivers
settings there
also
icon in taskbar
problem
connection is good
hope this helps
Labte pulse 285 speakers!
You won't find drivers for these Labtec speakers because they don't exist.They are plug-and-play speakers so they should work as soon as you plug them into your computer. But I have the same problem as you do (I had to format my comp as well and now I'm screwed because the speakers aren't recognized by the computer).
Labtec 285 Speaker System
I have the exact same problem, what i suggest is finding your manual, and CD to install (if u have one) because i remember this problem a while back when i first got it, but after i installed it was ok...if you dont have the manual or disk, you could look for an online instalation manual (which is what im doing right now)
Can i conect my labtech
Yes, as long as the plug fits you can.
Let me know if you have any other questions.
Best of luck!
Speakers conect to tv
Yes, as long as you can plug it in, it will work.
If you have any more questions, please feel free to ask.
Speakers conection
Speakers
- first findout the problem is due to speaker or from your computer soun driver or hardware.
- for checking speaker, connect to an ipod or walkman to the speaker input if it works the speaker is okay
- check the computer sound driver software may installed properly
- for these type dxdiag on run in the start menu
- check the sound driver problem, if it re install the sound driver by using its cd
Sound card query
What you'll need to do is identify what kind of sound card is in your laptop. The drivers for the laptop have either been corrupted or deleted by the virus. If you have a brand name laptop it most likely came with a recovery cd. Using this cd and doing a coplete restore of the system should fix your problem, however this will cause your laptop to lose all your custom settings and programs and what not. That's one option. You can probably find out what sound card your computer has by checking with the manufacture website under support. If you can give me the brand and model number of your laptop I can find out what kind of sound card you have, and then I will retrieve the drivers for you and give instructions on how to re-install those drivers. Drivers are software packages that tell your computer how to use hardware devices, in this case your sound card. Do I understand your problem correctly? You have no sound options or speaker icon on your laptops sytem tray down by the clock?
What's the part number for the operational amplifier ,DC 15dc of LCS 1024
why not photo the IC, and show that.
for 10x better answers.
not told what car is came out of or what the OBJECT did. (PCM/ECU/BCM ,etc?) <<< vast on cars/trucks\
many PCB or Modules the ICs are some or all , contract parts
and the number on top is secret contract Part number.
ahhhhhh it is not a CAR at all it is
LABTEC LCS-1024 AMPLIFIED COMPUTER SPEAKERS
moving you now to computers stuff
Can you hook up a Labtec 2424 sub to a smart TV
If you are looking for the top security companies in London that provides its customer with remarkable security services. Check out this site for security services https://www.urbansecurityguards.co.uk
