20 Most Recent Labtec Microphone Microphone Questions & Answers
This type of audio feedback loop can happen on any mic if you are playing back audio at a loud volume on speakers that are close to the mic while the mic is on - which tends to happen on Skype calls. Try lowering your speaker volume or using headphones to hear the audio, then speak into mic, and the feedback should be reduced.
Labtec... | Answered on Apr 14, 2012
  • Have you opened your C- media mixer to make sure the mic input is not muted and make sure the volume level is up? You can go to advanced controls and select it as the displayed unit if it is not initially displayed. This link can get you to your download should you need it. http://labtec.custhelp.com/app/answers/list
Regards, Tony
Labtec... | Answered on May 11, 2011
Go to your sound preferences and find "Output Audio" and set it to whatever option you like.
Labtec... | Answered on Mar 14, 2011
In addition to the instructions below you may need to make sure you have selected the right sound source (normally WAVE) in your recording program
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Labtec... | Answered on Feb 25, 2011
Click VOICE
That should be it.
Labtec... | Answered on Feb 18, 2011
as long as there is a "mic" plug on the PC then yes it will.
Labtec... | Answered on Jan 14, 2011
Check the Device Manager to see if it is discovered and connected with drivers installed. Otherwise, install the disk that came with the microphone to install the drivers. If it didn't come with the disk, reboot your computer with the microphone connected to the computer - upon boot, the computer should prompt and let you know a new device has been found and will install the drivers automatically.
Labtec... | Answered on Oct 25, 2010
If you are using skype, go to the upper left hand top and click on call. Then click on audio settings and make sure your microphone is listed as the mike to use in the window of the drop down menu. It should say logitech something in the window that says microphone.
Labtec... | Answered on Apr 24, 2009
Just plug it into the mic input on the sound card. All recent operating systems support it by default.
Labtec... | Answered on Jan 15, 2009
i had the same problem it's because your plugging it into the front of your computer....plug it in the back and it should work....there should be something that pops up or click in the right hand corner there's an icon that says sound afftect....you need to acknoledge that it's a mic not a cam that your plugging in
Labtec... | Answered on Nov 16, 2008
try to adjust the line in volume when you double click the volume icon, it may be muted
Labtec... | Answered on Jul 28, 2008
Labtec Microphone Microphone Logo
19 questions posted
Top Labtec Audio Players & Recorders Experts
Alun Cox
Tony Raia
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Labtec Audio Players & Recorders
Most Popular Question
horrible echo whenever try record 39 s
  • Audio Players & Recorders
