20 Most Recent Labtec LCS 2424 Computer Speakers Questions & Answers
In the sub? You opened the speaker?
Labtec LCS 2424... | Answered on Mar 05, 2015
WHICH OPERTING SYSTEM ???
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope it helps
Labtec LCS 2424... | Answered on Sep 16, 2012
Being windows vista is most likely is a driver problem. Is it internal or external sound system, not the card that works. If the manufacturer does not have an updated driver by now you can set the device to work like windows xp and it should only effect that device. Also search the web there are driver packs out there for windows vista, keep in mind its all the drivers for everything on one large compressed file so it should be a large file size.
Ultimately I would say upgrade to windows 7, its how windows vista should have worked. I have devices from windows 98 that work on win7 no problems. Vista was just very premature in its release. Hope this can help. Sorry for my bad spelling.
Labtec LCS 2424... | Answered on Oct 21, 2011
if u got the speakers from countries which use 110 u have it with 110 and if u got it from countries using 220 u have it with 220 capability
Labtec LCS 2424... | Answered on Feb 01, 2011
if your computer came with a disk the sounds drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Labtec LCS 2424... | Answered on Oct 26, 2010
Most speakers do not need any sort of software. All you have to do is to plug it in
Labtec LCS 2424... | Answered on Jul 22, 2010
Please 4 help. I need pins for wofer LABTEC LCS-2424 .
Labtec LCS 2424... | Answered on Apr 15, 2010
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Labtec LCS 2424... | Answered on Jan 23, 2010
Labtec LCS 2424 Computer Speakers Logo
30 questions posted
Top Labtec Audio Players & Recorders Experts
Alun Cox
Tony Raia
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Labtec Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Labtec Audio Players & Recorders
Most Popular Question
broken pin in connector speakers work
  • Audio Players & Recorders
