http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware.
SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud, automatically installing the most current, precise drivers for each individual PC. SlimDrivers features a one-click, start scan button on its product homepage, which begins the process automatically to scan a PC and identify out-of-date or broken drivers. Then, seamlessly, SlimDrivers creates a personalized driver profile of that PC, and accesses the online cloud database for the most up-to-date, customized driver software. hope it helps you
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
22 questions posted
13 Questions
14 Questions
22 Questions
12 Questions
13 Questions
