20 Most Recent Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Questions & Answers
No suction on dyson dc07
Hello, this is Ava with Think Crucial. If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris. Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it. Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum. You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=dyson I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
3/5/2017 10:32:31 PM • Dyson DC07 All... • Answered on Mar 05, 2017
My dyson dc07 has suction on the handle but not on the floor and the moter and the belt are working and I bought a new hose
click linh below http://www.fixya.com/support/t12737098-dyson_will_not_pick_up_but_suction_when
12/21/2016 11:08:50 AM • Dyson DC07 All... • Answered on Dec 21, 2016
The brush head won't stay on the floor.
Erin, check for a vacuum repair shop in your area, this is what they do and may have parts in stock. Check the attached link,instruction and guides, Good luck "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Dyson Vacuum Repair
4/18/2016 3:00:20 PM • Dyson DC07 All... • Answered on Apr 18, 2016
Dyson vacuum wand doesn't work
The manual for the DC07 can be found here ( 500 Error Dyson ) (The PDF tag is saying 'Error Dyson', but it still seems to work in getting to the document) The most likely issue, under-documented for most Dyson uprights, is that the wand suction will *only* engage when the main handle is in the full upright position. In that position, the brush motor will also always stop spinning. I found this out after much wondering when I bought a DC07 at a flea market. Got a great deal when I plugged it in there and couldn't get the brush to spin, and the storage locker clear-out guy just wanted to get rid of it. That said, it's a common point of dodgy documentation for the upright Dysons, IMO. It could also be line blockage. Remove and check the U-Bend piece, remove the hose line (un-clip at the bottom and pull off), stretch it, and see if there are obstructions. My fave way to deal with blocks in there is to use a pair of pliers to bend a small, blunt U-hook in a wire coat hanger that's been bent into 'marshmallow-roaster' long-skinny shape, then go in carefully from the ends and see if you can hook stuff and pull it out. Some crumpled paper can be amazingly effective at tenaciously holding to the walls. Be careful to look through the stretched hose wall when doing this to make sure you don't hook the hose wall and tear it. Good Luck!
11/4/2015 6:14:42 PM • Dyson DC07 All... • Answered on Nov 04, 2015
It doesn't turn on, it turns on for half a second then turns right back off. I don't think the plug it the original plug. (I received this vacuum as a hand-me-down)
I suggest a trip to an appliance centre to have the plug checked out as dimming house lights indicates a hugh short probably in the plug or lead Safety first
5/25/2015 5:08:01 AM • Dyson DC07 All... • Answered on May 25, 2015
Dyson brush latch broken
9/29/2014 9:03:31 PM • Dyson DC07 All... • Answered on Sep 29, 2014
How do you change the brush belt
Hi there, it's Jack at Dyson. DC07 All Floors doesn't include a traditional, user-replaceable belt. Instead it has a brush control clutch mechanism, so you can turn off the brush bar when cleaning hard floors. The belts in the clutch are engineered to last the lifetime of the machine in normal use. If you're concerned that the clutch doesn't seem to be working correctly, we'd appreciate the opportunity to take you through some quick troubleshooting checks over the phone. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We'll look forward to hearing from you.
9/11/2014 8:58:45 AM • Dyson DC07 All... • Answered on Sep 11, 2014
I HAVE PULLED THE ELECTIC CORD LOOSE, BUT CANNOT GET INTO THE DYSON TO CONNECT IT UP AGAIN. WHAT CAN I DO AS
The Roter Pulley inside may be locked by some dust materials , Try to pull the Wire outside little more to avoid the dust materials in the pathway they it will go inside
9/1/2014 10:13:20 AM • Dyson DC07 All... • Answered on Sep 01, 2014
2answers
I want to oil the bearings in my dyson dc07
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately this machine does not have bearings that you can oil. You can replace the bearings that are in each end of the brush roller by removing the brush, taking the end caps off and pulling out the bearing and putting new ones in (size 625 from memory). The bearing in the motor however is sealed and cannot be replaced. This model is designed to have a motor replaced if the bearing is failing. I dont know if this is terribly good news for you but it is accurate.
If you live in Australia you can get the bearings and motor from NelsonVacuums.com.au
5/25/2014 5:08:26 PM • Dyson DC07 All... • Answered on May 25, 2014
2answers
THe cyclone part is full of smelly fine dust
You have to take the filter out and clean it White Vinegar usually gets rid of bad household smells If it's a H filter you need to replace those every couple of months
5/2/2014 2:36:06 PM • Dyson DC07 All... • Answered on May 02, 2014
2answers
How do I clean behind the fine net on the cyclone unit
Hi, CLEANING BEHIND THE CYCLONE MESH 1. Detach the Cyclone and bin from the main body as you would when emptying. 2. Standing over a bin. empty the contents of the cyclone by pulling the bin flap release button upwards. 3. Whilst the flap is still down detach the bin from the cyclone by pushing up the button on the middle of the cyclone. 4. Sit the bin to the side as you dont need to use it. 5. Get a pair of pliers 6. Use the pliers to pull the fins from the bottom of the cyclone. 1 by one you will hear them click out of position. When you pull the 4th and final fin the baffle will detach and you will then be able to clean the baffle and also the cyclone.
5/2/2014 2:34:14 PM • Dyson DC07 All... • Answered on May 02, 2014
2answers
DOES A DYSON HAVE AN AUTOMATIC SHUT OFF VALVE
The motor has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, the moment it is switched on, it just trips again.
It cannot be reset manually.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
3/20/2014 5:53:25 PM • Dyson DC07 All... • Answered on Mar 20, 2014
Dc 28 won't turn on
Start with checking the cord and switch
1/29/2014 5:44:52 AM • Dyson DC07 All... • Answered on Jan 29, 2014
Very loud but works great
Some cleaners are notoriously loud. Nature of the unit. Others are quieter.
11/28/2013 7:48:23 PM • Dyson DC07 All... • Answered on Nov 28, 2013
Dyson DC07 is very loud, roaring from the motor
It usually gets louder as the filters clog up and eventually burns out. Try replacing all the filters and giving the bin and the vortex generator a good blow out with compressed air. Fluff can stay inside and cause the motor to strain hence the increased noise.
It must still be under warranty -used to be 3 but now 5 years -so if it doesn't improve contact Dyson and they will repair it free of charge.
1/21/2013 3:47:11 PM • Dyson DC07 All... • Answered on Jan 21, 2013
How do I rebuild my dyson
without more information id say pull U shaped pipe off bottom and then re-install new hose at bottom then slide handle down into it snapping it in at top. if this doesn't help please feel free to respond with more info and maybe a pic
1/8/2013 11:29:45 PM • Dyson DC07 All... • Answered on Jan 08, 2013
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
116 questions posted
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Dyson Vacuums
  • Dyson Vacuums
Most Popular Question
brush head stay floor
  • Vacuums
