20 Most Recent
Mustek Plug-n-Scan 600 Flatbed Scanner Questions & Answers
Have downloaded a driver for
First install software driver if finish, connect your scanner USB cable to USB ports of CPU(make sure that your USB ports working good, test also using your USB flash drive).then you can see on screen automatic detect your scanner. if not detected try to change your USB scanner data cable. then try again connect to USB ports of CPU.
Just let me know if not yet working.
Thanks for using Fixya.
7/13/2011 11:54:51 AM •
Mustek...
Answered
on Jul 13, 2011
Hi there - I have an older Mustek Plug-n-scan
Most computer accessories, printers and scanners today use USB connectors between the unit and the computer. The older scanners do not have USB capability and will not be compatible with the newer computers. Only with add-on cards and cables can they be made to work.
As for selling it you would do better to donate it to Goodwill etc and get the tax donation slip for it.
If your scanner does have the newer USB connector, you will only have a $10 +/- scanner. The software, Corel Draw is outdated and not compatible with the new operating systems. There may be an update available from Corel which may require a prior product registration to qualify for. However most software packages included with printer and scanners etc are "SE" special editions, which are very basic trial versions and not the full featured retail versions.
4/13/2011 10:30:19 PM •
Mustek...
Answered
on Apr 13, 2011
I am running WIndows 7 and my scaner Mustek 1200
New operating system same old problem
Contact Mustek to see if they have an upgrade set or you will need to wait till someone gets around to either writing a new one or hacking a new one
10/23/2009 8:15:58 AM •
Mustek...
Answered
on Oct 23, 2009
Please I need the driver to install a scaner
download your driver for mustek scanner 600 from the given link..
try it all the best..
http://www.lostmydrivers.com/driver/download/14564/Mustek/Scanner-Drivers/mustek-600-ii-ep-scanner-driver-3.7-windows-9x-me.
6/22/2009 8:10:08 AM •
Mustek...
Answered
on Jun 22, 2009
How to instal Mustek cu 600 scanner with win xp
there is not drivers or software made for Windows XP.
however, you can use the win98 or WinME software. as long as the Windows Xp is running at 32 bits. I have done that with HP flat bed scaner.
don't worry about the non-certified software with MS.
1/8/2009 1:15:59 AM •
Mustek...
Answered
on Jan 08, 2009
Is ther a driver vor Mustek P3600 A3 Pro for Windows 10?
Yes, there is a driver available for the Mustek P3600 A3 Pro for Windows 10. The driver can be downloaded from the official Mustek website [1], or from the Windows Update tool [2]. Once the driver is installed, it is important to keep the drivers updated in order to maintain the functionality of your computer [3]. Additionally, using a driver updater such as DriverDoc can be beneficial in keeping all of your PC drivers updated [2].
<b>References:</b>
<span>[1] <a href='https://www.mustek.de/drivers/index.php?stap=3&category=Scanners&product=p3600_a3_pro' target='_blank' class='text-purple-1 underline'>Scanners > P3600 A3 PRO - Mustek Driver & Support</a></span>
<span>[2] <a href='https://www.solvusoft.com/en/update/drivers/scanner/mustek/p-3600-a3-pro/sub-models/' target='_blank' class='text-purple-1 underline'>Mustek P 3600 A3 Pro Drivers Download - Scanner - Solvusoft</a></span>
<span>[3] <a href='https://www.driverscape.com/download/p3600-a3-pro-wia-scanner' target='_blank' class='text-purple-1 underline'>P3600 A3 Pro WIA Scanner Drivers Download</a></span>
Written by Chatsonic
