20 Most Recent
Mustek Scan Express 1248UB Flatbed Scanner Questions & Answers
Driver Scanner 1248ub Driver for
Unfortunately, there is no compatible driver for win 7. THe Mustek support center says the following:
Scanners designed to work with older versions of Windows may not function
properly after upgrading your computer's operating system.
If Windows® 7 is not listed on the product driver download page for a
specific product, no support is offered for Windows® 7. Newer scanner products
available will have support for Windows® 7.
Scan is not clear
Hi. The fuzzy might be the glass needing cleaning (both sides) and the grainy scans could be that the scan resolution has been accidentally changed.
I have just install my
You should be able to use the advanced options in the scanner software to adjust the hue or contract of your scans. Tweaking these settings will help you balance out the colors. You could also use a photo edit program to adjust these settings though I'm sure the scanner has the capability built into its software.
If you need the manual for this device you could try emailing the manufacture and ask them to email you the manual.
[email protected]
Regards,
Chris
Driver per installazione
Buongiorno,il driver necessario a questa periferica si trova a questo indirizzo.http://www.mustek.com.tw/Support/Sono a disposizione per ulteriore aiuto.Saluti
I have Mustek 1248US. Can it scan to PDF?
Scan to PDF is controlled by your software. What OS and software are you running? Under Windows, Nuance's PaperPort,
http://www.nuance.com (or OmniPage which includes PaperPort) or Abby Fine Reader Express, http://www.Abby.com , both will let you scan to PDF. Open the software and set the options for scanning to PDF. Then press the scan button in the software. (Depending on the OS and Mustek driver, you may get this to work by pressing the Scan button on the scanner itself. This depends on installing a monitoring program that may be included in the drivers. This "listens" for the button press and then launches the desired software.) Other third-party software may also do this.If you are using something like Windows Fax and Scan, you'll have to do two steps. Scan and then convert the file from an image to PDF. (There are dedicated programs that convert image files to PDF or you can do this is Microsoft Office or other office suites with the appropriate add-on.) I hope this helps. Cindy Wells(I have an older scanner with Windows 7; I can only scan to PDF with third-party software.)
