20 Most Recent
Canon Sure Shot 80U 35mm Point and Shoot Camera Questions & Answers
Camera does not rewind after
it is likely that this model of camera spins the entire roll onto the take-up spool, and then slowly rewinds one frame at a time until the last picture is taken. Then it has already almost rewound,
This shows up when you load the film. The cameras digital counter counts up to the number of pictures available, and counts downward each picture taken.
Camera is flashing "H"
I've done some research and found out that the flashing H is Electronic failure and needs repair.
How do you set the time on the Canon sure shot 80u
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Date and time
CANNON SURE SHOT 80U
Film advance
throw it away, its already old, buy new ones a pentax g40, its a computer compatible.
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'.
I think the other answer is an AI Answer Bot.
