20 Most Recent
Canon PowerShot G1 Digital Camera Questions & Answers
Canon PowerShot G1: If
No. The coin battery only powers the memory for the camera settings such as date & time. I suspect you have a chip failure and will need to send the camera off for repair. I know, I know,.... these repair places are a rip-off because they quote a flat rate for repair, even if it's a $3.00 chip set.
Error code
I found the answer on another site and was able to fix my camera myself. E24 means your LCD display has come unplugged. What happens if you rotate the screen too much you tighten up the wire and it pulls the connection out of its socket. There ar 4 screws on hedispla, unscrew ad take th back off the screen. Unwind the screen until the wires loosen up. Replug in the loose connector. Resecure the back
PowerShot G1 + cf card
The Canon G1 was my first digital camera, years ago. When this camera was sold it came with a 16 Mb CF card. The manual refers to CF card sizes from 8 Mb up to 128 Mb and the number of photos you can take with each size card. However, I bought my camera together with a 1GB "micro drive" (tiny hard drive in a CF card format) and although it wasn't "supported" by Canon, it worked fine. I also used a regular 1GB CF card in it (after I lost the microdrive card). If you want to use a card larger than 1GB with this camera, test/borrow a card to make sure it works before you buy one. Camera stores always have a variety of cards (used to demonstrate the cameras they are selling) that you can put in your camera and test before you decide which card to buy.
Canon Powershot G1
Power problem .. I guess most likley a bad battery or dirty power contacts
Canon g1 off!!
Power problem .. check your Manual .. is there a 'back up' battery (coin cell) ????
G1 camera will not charge its battery
Check this out http://www.fixya.com/support/t103944-canon_parwesh
or_s400_ixus
or Here
http://www.fixya.com/support/p294058-canon_powershot_g1_digital_camera
