20 Most Recent
M-Audio Solaris Professional Microphone Questions & Answers
Recording for a group
Good advice at this site:http://www.dancetech.com/index.cfm?loading=section_links&class=tech Scroll down to the Studio Tech articles.
My M-Audio Solaris mic fell
Unfortunately, most condenser microphones (like the Solaris) are fairly fragile. The fluctuations and noise you're hearing is most likely from damage to the sensitive capsule inside the mesh screen. If that is the case you will want to get a return authorization number from M-Audio and send it back to them. You can find all the info and forms here:
http://www.m-audio.com/index.php?do=company.warranty
There is a slim chance your issue could just be a loose wire or resistor inside the casing, but very unlikely. It's not really a mic that is considered "user serviceable," but if it's definitely out of warranty you could try a local electronics shop.
I know it's probably not the answer you want to hear but it sounds like you need the capsule replaced from the factory. With any condenser mic always remember to use a shockmount, sturdy mic stand, and keep loose mic cables out of the way.
Good Luck,
Dan
Bass Guitar Won't Register
The mics I have seen don't have a filter... but a lot of mixers do have a 100Hz mic input filter. Check the other equipment that you are using also.
Audio bx5a tweeter
Tweeter just may need to be replaced. Is all the sound coming only from the woofer?
Loud rattling noise
hey shawn, try lowering the volumne level & see how the speakers react. www.tiger direct.com has new computer speakers,all different prices & different quality levels. from the best to the cheapest computer speakers.they carry all computer parts. 2 tb hard drives, $89.00for usb2 & usb 3 ports.
My fast track pro keeps
Do you have a "circuit protection" light or sign?
If not, you most likely have a faulty power supply like so many others with newer electronics now days. It should be tested with voltmeter to see if power supply is putting out a constant voltage reading. If it isn't, it may have bad capacitors in the unit. Bad caps will cause tv not to power or stay on.
